Here is a vid on using gauges to sync the carbs. Links for where to purchase the vacuum gauges and 3D'd adapters are posted in the show more section. Enjoyed the beginning and end shots.
https://youtu.be/rzc_Nz82e1o
Carb sync with gauges
Re: Carb sync with gauges
That was pretty good. It would be nice to have a little more resolution on the gauges. It looks like there are many of these things available to choose from. I might look into this a little further. Thanks LC!
Ken's Garage
Your welcome. Note that the adapter link (6mm to 16mm) is not a sale item but a 3 image maybe to create said item. Don't have a 3d printer. I imagine there is a combo of hose adapters to fit create it. Also looked into the vacuum gauge brand the vid suggest for twin rz/rd's. Found a set but did not come with the valves to steady the needles. I suspect a valve could be attached from Lordco etc to deal with that issue. I'll be doing a little homework on that myself. Props to Postpros for creating the vid.
- IMG_4459.JPG (67.26 KiB) Viewed 598 times
