Hi All,
Been a bit. Picked up a bike from Rory so i've been digging through my boxes of parts. Amazing how much you can forget about these bikes in a few yrs.
I've got a transmission sitting in a bag here. Fairly sure its a banshee one from the motor that went in the RS but can't be sure.
What's the best way to determine which version tranny it is? Guessing counting teeth? If so, what's the best way?
If I absolutely have to I can get a RZ trans out of a motor and check but its a bit of a task.
Many thanks!
Evan
Banshee vs RZ transmission ID'ing
Re: Banshee vs RZ transmission ID'ing
Anyone looking in future here are the ratios.
Banshee ratios
1st gear ratio: 32/13, 2.461
2nd gear ratio: 29/16, 1.812
3rd gear ratio: 27/18, 1.500
4th gear ratio: 25/20, 1.250
5th gear ratio: 23/22, 1.045
6th gear ratio: 21/24, 0.875
RZ ratios
Transmission 1st gear ratio: 36/14, 2.571
Transmission 2nd gear ratio: 32/18, 1.778
Transmission 3rd gear ratio: 29/22,1.318
Transmission 4th gear ratio: 26/24, 1.083
Transmission 5th gear ratio: 25/26, 0.962
Transmission 6th gear ratio: 24/27, 0.888
Banshee ratios
RZ ratios
