BILLET CARB MANIFOLD WITH VACUUM OPTION
- two-stroke-brit
HI All, is there a billet manifold that has the option to run vacuum lines for the purpose of balancing the carbs.
or could the balance bottle/pipe ports in the rubber manifolds be used.
thanks mark
thanks mark
Re: BILLET CARB MANIFOLD WITH VACUUM OPTION
I have an RD350LC and use a block off for the cross over tube on the reed blocks. I drilled and tapped them for vacuum take off. I then use a Twinmax for balancing.
I would provide pictures if I can figure out how to do that. or provide your email address and I will send them to you.
Frank
Frank
1971 Kawasaki F5a Big Horn
2013 NC700X
2013 NC700X
- two-stroke-brit
email addy sent in PM.
cheers mark
cheers mark
I have adapters that replace the cross over pipe. i drilled and taped for vacuum takeoff. Works well.
2013 NC700X
2013 NC700X
- two-stroke-brit
yep made some up and it works a treat dont need to remove anything apart from the balance pipe.
thanks for the tip
mark
thanks for the tip
mark
Hi Mark! Can you share the drawing to make said adaptors please? I need to knock a pair up too!
85 RZ350
88 YSR50
82 RD350LC (Current project)
97 Honda RS125 (race bike #1)
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
88 YSR50
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
Yes me too, please :)
- two-stroke-brit
WILL DO .
BUT THEY ARE SIMPLE PARTS
MARK
MARK
Thanks Mark, Simple is good. Even i could probably make them on a lathe :)
Even a pic would help, but dims are always good if you have them. thanks mate.
- two-stroke-brit
i used 16 mm aluminium rod . drilled and tapped a 1/8th npt thread to suit the barbed adapters.
They could be improved by using 19mm rod and leaving a 1mm shoulder to stop them going too deep.
i got the basic format from another member.
with the fish tank valves acting as dampers to stop the needles fluctuating wildly.
drawing/writing with a mouse is "Pish" as my Scots buddy would say.
cheers mark
cheers mark
Very cool, Thanks Mark!
What are fish tank valves?
Those look so familiar...
- two-stroke-brit
they are small plastic thumb valves that restrict the flow of air which act as dampers
two-stroke-brit wrote: ↑Sun Feb 07, 2021 2:00 pmthey are small plastic thumb valves that restrict the flow of air which act as dampers
are they like one way flow valves Mark or just a tap?
- two-stroke-brit
I don't know for sure but assume them to be simple restriction valves.
i will check one out and update if it is a one way deal.
cheers mark
cheers mark
