Project Incognito
Re: Project Incognito
Also ran the wiring & tubing through the headlight bracket. Yellow ties are temporary.
Bike is starting to look proper. Still needs a lot of mods.
Forgot to say that I rubber mounted the headlight bracket. Everything needs to be rubber mounted. Still a two-stroker at heart.
Need to get a front caliper adapter, and finish the custom bike lift before installing these new rotors. Went through some shit to get these particular discontinued rotors. Sizing up on the front from 180mm to 203mm. Also want to get the correct Galfer e-bike pads. Galfer stuff has been all good on my motorcycles. Would also like to install street tires at the same time.
getting better n better. Reminds me of the WR you did. :)
Thanks, Jon.
First of all, decided yesterday- NO MORE JUMPS. NO MORE DROP-OFFS. Okay, for suspension testing- but that's it. Suspension isn't plush enough, and I'm definitely going to make my injuries worse. First thing I did today was pull out of the driveway and drop off the curb. Old habits die hard.
Fixed the loose grip with a little teflon tape underneath.
The height of the handlebar with the new riser is great. Very comfortable when standing. Transportation mode = sitting down, with full-throttle only- unless too dangerous. Joyriding mode = standing up only.
I've got the Ohlins rear shock, but don't see any Ohlins forks or cartridges for this bike. May as well go for some Fauxhlins while I'm still looking. Got some decals. Obviously fakes- check out the f'd up warning sticker.
Some progress on the swingarm pivot lift.
Nice to see some fabbing, cool idea.
Hope this link works. Pretty sure I got the info I need, but don't want to lose it, yet.
There's a hesitation, or ramp-up (not sure exactly how to describe it) with this throttle set-up. Got a feeling it's for safety, because the torque hit can be unexpected. Looks like this mod is a good fix.
Not sure what the cost will be. Might be good to wait and get some more use out of this battery before rebuilding it to 60V. An OEM replacement battery is $750 usd, but always "Sold Out", so rebuilding seems to be the only option. Not sure on the price of the 60V controller and screen.
Will keep trying to get more info on this mod. I'm used to the throttle hesitation, but really don't like it.
https://video.search.yahoo.com/video/pl ... mob-s&tt=b
Yeah, for me, too. Still haven't made new contacts for machining. Welding Lab instructor got the Machine Tool instructor to do it, right now! Had to scrub down one pin with sandpaper for a perfect slip fit.
Not happy with the welding on these. I didn't want to warp the tubes at all, so I didn't go deep with the welds. If I can add strong fillet welds, then it's all good. If not, It's easy to cut more square tubing for another try.
Then, I'll try some lap welds on angle aluminum to the base plate. Again, worried about warpage.
Cut the angle brackets for the lift. They should work fine, but I don't like the way they look. Will style them up a bit tonight.
If I weld the uprights to the brackets, it'll be more difficult to get the lift into position- so I'll do some drilling & filing, and attach them with M8 bolts.
Nothing exciting, but at least I'm doing work.
Tapered the sides down to 1 inch and cut the bases from 3x3 to 3x2 inch.
Cut openings for the jack bolts. Forgot the inside radius cuts. The heat is brutal and was definitely affecting my brain. It's okay, though.
Getting there.
Took some time to mock it up on the bike and figure out exactly where to weld the brackets. Wasn't easy, but it's looking good. Might not look so good after welding, but I just hope it works.
Lab was closed for a couple of months. Started welding again this week.
Lift project is now working, but still needs a bit of finishing.
Need to order some more parts for the bike.
My brain is slowly fading away. It's sad, but I'll carry on. No choice. No one to rely on. Forced to ride the supermoto to welding class tonight. If I miss a class, the instructor will be calling me to make sure I'm OK. He's that kind of guy. He knows whats was up and said he would pick me up at home and drive me home from class, no problem.
What's up is just more stupidity. I've had the e-bike for months and have no spare tube, or even a patch kit. I did get a very small MTB pump. I've been trying hard for a while to find a 20x4" tube from a good manufacturer. None from Pirelli, Michelin, BFG, Conti, Goodyear, Bell, etc. They all make bike tubes, but not in my size. Even Schwalbe and other bike tire companies have nothing available. Kenda has them, but hard to find in stock. I got an unknown (to me) brand called 1PZ. There are tons of unnamed brand tubes and the reviews are shit.
Bike's been down for a couple of days. Thankfully, I was able to ride home before the tire went flat. New tube arrived tonight. But, a patch kit is supposed to arrive by tomorrow night. Think I'll try to patch the old tube first.
Very happy I got the lift done in time! Bike is up and off the rim.
Hoping to put some more wear on the tires and brakes before upgrading. Need to get some blingy hardware, too.
Almost got busted riding the supermoto on campus tonight. Maintenance man tried to block the utility road with his golf cart. Blew by him, just in time!
