![Image](https://i.postimg.cc/02n4T8Pv/20230519-225230.jpg)
You probably know by now, there's no such thing as good luck in my life. The shock bolts aren't hollow, and the male bolts are only 12mm. I think I can figure out a good solution with thick washers/spacers.
When I measured the OEM shock eye hardware, the top measured 24.5mm but, I noticed it's slightly (too) loose. Got a feeling it should be 25mm. I guess we'll find out soon.
According to Ohlins USA, the SAE Formula spring they recommended may actually be too short (when I called them back with the specs)- but couldn't tell me for sure. They said I may be able to use a POM spacer, and where to get it. So, I ordered the spring (not the custom spring). Will probably order the Ohlins shock on Monday.
