Hello gentlemen. I recently purchased my second Rz 350 in the past 10 years. So, i’m fairly familiar with most things related. The first bike I sold. The recent bike has an oil pump but it’s not hooked up. No hoses, no cables etc. I prefer to start using the pump for several reasons. What I need help with is the cable hook up and the oil hoses. I understand the oil hoses attach to the carb and where they attach. But, I need help with which hose hookup to specific pump nipple, routing, etc. Same deal with cable to pump information needed. If someone would be so kind to post a diagram I would really appreciate that kindness,
Thank you
Need help with oil pump
- Evans Ward
Re: Need help with oil pump
This may help to get you started and I’m sure others will chime in to answer specific routing questions.
- Evans Ward
Here ya go from the Factory Shop Manual:
Exactly what I was looking for Evans Ward. Thank you, very much
- Evans Ward
You’re welcome and glad to be of service to you!
