rd400 left side engine case.
kramdau
#1 Post by kramdau » Sat Oct 15, 2022 9:31 am
i bought a 1975 rd350 after i haven't had one for a few years. i knew something didn't look right with the left engine cover because i could see the counter shaft sprocket. i didn't realize that the previous owner put a rd400 case on the rd350. i didn't figure it out until the engine cover bolt kit i bought bolts were to short for the ignition cover. i have done google searches for the purpose of replacing the case but found nothing. The only thing i can think of is the clutch mechanism is better.
any thoughts?
mark
kpke
Re: rd400 left side engine case.
#2 Post by kpke » Mon Oct 17, 2022 9:03 am
You might get more response posting your question here
http://www.2strokeworld.net/forum/index.php
It is more geared toward air cooled Yamaha's.
Good luck!
kramdau
#3 Post by kramdau » Mon Oct 17, 2022 12:23 pm
thank you
