In order to remove the lower head, is it essential to remove the radiator, or will the head slip off the studs without the radiator interfering?
Stefan
Removing lower heads
Re: Removing lower heads
It will come off with the radiator in
Great news, thanks. I am not sure yet if I will remove it. An inspection through the exhaust port revealed a healthy looking barrel in the small area I can see opposite. Still thinking about if to remove it or not.
- two-stroke-brit
if you are just curios ..a small 7mm camera conected to your a laptop can go through the spark plug hole for insection
