V4 Heaven
#31
Post
by V4 Heaven » Sat Jan 05, 2013 8:12 pm
[quote="jackson.40"]The 1GE spec bikes didn`t have the rubber dampers fitted on the exhaust protector and had rubber foam strips on the bottom of the fuel tank instead.
Is the heatshield behind the fuel tank bracket standard (underneath where the seat would .... er...sit)? Mine doesn't have this. One of the 9 other owners must have binned it!
Gettin' kinda squirrely!
jackson.40
![***** *****](./images/ranks/gold_rank_button-7.gif)
#32
Post
by jackson.40 » Sun Jan 06, 2013 6:21 am
Yes it`s a 1GE only item
V4 Heaven
#33
Post
by V4 Heaven » Sat Jan 26, 2013 7:11 pm
Thanks Steve, mine shouldn't have it then (47x).
rd84
![- - - - - - - - - -](./images/ranks/contributor_grey.gif)
#34
Post
by rd84 » Sun Jan 27, 2013 11:38 am
V4 Heaven wrote:Thanks Steve, mine shouldn't have it then (47x).
You need the bright zinc plated steel heat shield.
V4 Heaven
#35
Post
by V4 Heaven » Mon Jan 28, 2013 5:13 pm
I have one. I'm sure it was bright zinc once. It's nearly rusted through!
rd84
#36
Post
by rd84 » Tue Jan 29, 2013 8:31 am
V4 Heaven wrote:I have one. I'm sure it was bright zinc once. It's nearly rusted through!
They do seem to have a tendancy to do that !
begbie
#37
Post
by begbie » Fri Feb 15, 2013 10:06 am
i have one 1ge stamped lower exhaust and one 47x , question is are the expansion dimensions the same ?
top two are 47x and i have a 1ge engine will this be ok ?
jackson.40
#38
Post
by jackson.40 » Thu Mar 10, 2016 2:14 pm
I wondered if you guy's with 1GE bikes could check something for me?
In the 1GE parts list the rear fender has an extra clip not found on the 47X bikes.
I was looking at a 1GE pre-production bike today and it has this clip,i was just wondering if this clip made it onto the production bikes.
Item 22
![Image](http://i19.photobucket.com/albums/b170/jackson500/PRE-PRODUCTION%20RESTORE%201GE%2054_zps1gzd3eey.jpg)
Speed Freak
#39
Post
by Speed Freak » Thu Mar 10, 2016 5:48 pm
From my 1GE bike:
![Image](http://abload.de/img/90464-16021t8sfy.jpg)
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
jackson.40
#40
Post
by jackson.40 » Fri Mar 11, 2016 2:24 am
Do you have item 22 on your rear mudguard?
Speed Freak
#41
Post
by Speed Freak » Fri Mar 11, 2016 12:46 pm
I did not make any notes about this part during disassembling, so it should be there as in the parts manual - 21 and 22 are the same part number.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
jackson.40
#42
Post
by jackson.40 » Fri Mar 11, 2016 2:31 pm
It would be great if some people could check their bikes just to confirm this clip is fitted
podman
#43
Post
by podman » Fri Mar 11, 2016 5:13 pm
jackson.40 wrote:It would be great if some people could check their bikes just to confirm this clip is fitted
Its on mine, which is amazing as f'all else seems to be...
![:smt003](./images/smilies/003.gif)
![IMG_0489.JPG](./download/file.php?id=388&sid=f2e13b1cbd7987ce9e25f583984ea7f8)
- IMG_0489.JPG (120.92 KiB) Viewed 6428 times
Speed Freak
#44
Post
by Speed Freak » Fri Mar 11, 2016 5:24 pm
As I said, i did not make notes about the part - it has to be there, otherwise I would have it as a missing part in my list.
And i can find it at shelf 1 second row from the top...
![:smt005](./images/smilies/005.gif)
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
