solo seat leads?
General forum on fairings, seats, tanks, tail sections, painting and other bodywork modifications
JonW
Contact:
Re: solo seat leads?
#46 Post by JonW » Sun Sep 30, 2018 4:41 am
Evans Ward wrote:O ring size needed for rear hold is: 42-43mm in round unstretched form.
Thats great info, Thanks for that.
see them all at www.2smoked.com
80 XT500 Supermoto!
81 RD350LC Resto
82 RD 421 LC Hybrid
82 RD 250 '51L' YPVS LC
83 RZ350 LC2 Resto
85 RZ350 F1 Resto
84 RZ500 Resto
86 RZ350 F2 Hybrid
Like Watches? Try www.PloProf.com and www.DeskDivers.com
savethe2strokes
#47 Post by savethe2strokes » Sun Sep 30, 2018 6:32 pm
I still want a solo cowl. I just don't know where to get one from. I asked one guy glassndude to make one, but he keeps blowing me off.
85 RZ350-Messed up wiring
brrrappp
#48 Post by brrrappp » Mon Oct 01, 2018 2:35 pm
savethe2strokes wrote:I still want a solo cowl. I just don't know where to get one from. I asked one guy glassndude to make one, but he keeps blowing me off.
http://www.rzsunlimited.com" onclick="window.open(this.href);return false; has complete cowl and the hold-down brackets.
As with all the plastics for these bike......they don't came cheaply.
I see the cowls on eBay from time to time in rough shape. A crappy beat up fiberglass reproduction just sold for $125 USD
It's easier to find entire complete RZ350's that have the cowl than it is to find the cowl only.
A modest "high" can be obtained by listening carefully to the sound of a 2-stroke hitting the fat part of the powerband while inhaling cool fall air tainted by the exhaust scent of VP-C12 and Golden Spectro, mixed at 24:1.
Evans Ward
#49 Post by Evans Ward » Mon Oct 01, 2018 2:42 pm
You're welcome. That is measured at the circumference of the outer diameter too.
84 RZ350-Toomeys,SCR milled head, stk 26 carbs,300 M, 35 P, stock regrooved needles AS 2.5 turns out,stk air box,Banshee reeds Zeel non-progr CDI,TSRL Program YPVS,alum rad,R6 shock,GV emulators w/RT springs,fork brace,Shindy steering damper.
ZedSledder
Contact:
#50 Post by ZedSledder » Mon Oct 08, 2018 4:38 pm
https://www.ebay.com/itm/Yamaha-RD350-Y ... SwPcVV1ag0" onclick="window.open(this.href);return false;
1985 Canadian Rz350. Restored with collector plates. Stock VM26, Triumph Calipers, Galfer brake lines. Brand new DG’s, 260 main, 22.5 pilot jet. Economy pre-load adjusters. Ohlins shock. Oem Banshee crank.
brrrappp
#51 Post by brrrappp » Tue Oct 09, 2018 2:11 am
Those look really close to OEM. I ordered a pair of the stainless reproductions from RZsunlimited. They should arrive any day now. I'll post a pict of what they look like when I get them.
RuZty
#52 Post by RuZty » Tue Oct 09, 2018 6:48 am
I bought an Airtech one through Rory, picture here; viewtopic.php?f=5&t=11880&hilit=Airtech&start=255" onclick="window.open(this.href);return false;
I already had brackets and pad from CruizinImage. Since I don't have OEM rear signals and the Airtech seat doesn't have the hooks, I don't use the O-rings and it hasn't been a problem so far.
Bald Anthony
#53 Post by Bald Anthony » Tue Oct 09, 2018 9:18 am
mountaincycle wrote:looking for a solo seat/cowl rear section for my RZ350... I really like the cowl that goes over the factory seat.
any advice?
Here you go:
viewtopic.php?f=10&t=15656
brrrappp
#54 Post by brrrappp » Fri Oct 12, 2018 10:25 am
Stock mounting brackets / RZSUnlimited
The black ones are original.
The unpainted ones are stainless made by RZSunlimited. They look like they should do the job nicely and they included some O-Rings.
ZedSledder
Contact:
#55 Post by ZedSledder » Fri Oct 12, 2018 3:41 pm
Those look great. I’ll try and get a set as spares. The black paint on the asian reproductions comes off almost imediatley so i reckon stainless steel ones are a plus. I’m going to get an airtech piece and paint it at the same time as my extra gas tank. I just wonder why the are useing polyester resin instead of epoxy resin like the rest of the world? I do know from experience you can put epoxy resin on top of polyester resin but not the other way around.
brrrappp
#56 Post by brrrappp » Fri Oct 12, 2018 4:05 pm
Just so it clear- in the top picture that shows 4 brackets, the black ones 1st and last are OEM original. The two in the middle are RZSUnlimited. The second picture is a better picture of the originals.
RZSUnlimited said they do paint work there as well. The pictures he sent of painted parts look like they do some really good work. They clear-coat over the decals when they paint the plastics vs Yamaha only clear-coats the tank.
savethe2strokes
#57 Post by savethe2strokes » Mon Jan 14, 2019 11:10 am
I haven't had any luck with getting a Solo Cowl. Airtech said they don't put the keyhole on their cowl. For a roadgoing bike that can be an issue. Are there any other options?
peddro
Contact:
#58 Post by peddro » Mon Jan 14, 2019 12:20 pm
I am currently making molds for the solo cowl.
As I have got a project for 2 customers making 350YPVS parts, & was asked if I would also make the solo cowl while I was making the other parts.
I collected a brand new still in the box never fitted Replica (fiberglass) cowl from a customer just before Christmas.
I have had to modify it a great deal, as it would never have fitted on to a bike as it was trimmed incorrectly, ect ect .... (it was shocking)
So I discussed this with my customer & he very kindly loaned me his RD350 YPVS so that I could modify it so that would fit his bike properly before I made the molds.
The angle of the cowl didn't match the side panel on either side, also the panel gaps needed to be altered.
So after a lot of modifications the cowl now fits properly so I am happy to continue making the molds which should be finished later this week.
cowl now matches the angle of the side panels.
It also has the key hole in the correct place, as that also had to be "moved"!
So the hole will leave a slight imprint in the mold, so I can cut the hole and it will be in the correct place.
fitted
As discussed with the Moderator I will post a thread later in January once the molds and parts are made.
I hope this helps
Best regards
Johnny C.
john@vskcorrinaldi.co.uk
http://www.vskcorrinaldi.co.uk/
tacky1
#59 Post by tacky1 » Mon Jan 14, 2019 2:37 pm
Coming together great Johnny. Keep up the good work.
