My completed 85 RZ hybrid project
RZed
#1 Post by RZed » Thu Mar 07, 2013 12:23 am
Hello all,
I just finished up my project recently, and thought I'd share the results. I think it turned out pretty good for my first build.
It took about 3 months to do the build. Lots of trial and error finding a rear shock that works with that particular swingarm.
And some of the brackets and bushings I had to make. The bike rides real nice. In the future, I will re-valve the rear shock and put on a steering damper.
The parts list includes:
99 R1 complete front end
Tarrozi Hi-rise clipons
VJ23 swingarm
SV 650 rear wheel
SV 650 rear brake caliper
JL GP stainless pipes
Charlie
99 R1 USD front end
VJ23 swingarm
2018 XSR 900
RGVSteve
Re: My completed 85 RZ hybrid project
#2 Post by RGVSteve » Thu Mar 07, 2013 12:51 am
RZed,
VJ22 shock works with the VJ23 swingarm,when you use the adapter brackets that bolt to the lower center stand bracket. Using the VJ23 brake calipher and bracket would allow you to get
rid of having to use the brake stay arm. Bike looks nice.
aaronmvrider
#3 Post by aaronmvrider » Thu Mar 07, 2013 12:57 am
very tough looking bike.... love it....
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
Benno #03
#4 Post by Benno #03 » Thu Mar 07, 2013 2:02 am
3 Months, Bugger me.
Nice work, looks like she can be a daily rider too.
Not too much bling to worry about riding it everyday/where, you obviously don't mind it getting wet.
I like it a lot. Well done.
76 TZ350(project).
82 RD350LC.
82 SR250.
83 RZ350YPVS.
88 RZ250 YPVS(project).
83 FJ1100.
96 YZF750R(track bike).
99 YZF1000 R1.
00 YZF1000 R1.
72 CB750four.
Lifan 125 Pitbike.
Hooligan
#5 Post by Hooligan » Thu Mar 07, 2013 2:18 am
Interesting and pretty.
I have tried to instal an SV650 rear wheel into an LC frame and it is too wide to fit without modifying the frame and fitting an offset sprocket. Seeing as the LC and RZ motors are essentially the same bottom end I am wondering how you got everything to fit?
'81 RD350LC hybrid project bike - in pieces currently
'82 RD350LC in '81 colours - Built by "Solo 2" OEM pipes, UNI filters
'90 RZ350F2 with 31K motor, OEM F2 pipes & airbox
#6 Post by RuZty » Thu Mar 07, 2013 7:16 am
Superb! :smt023 :smt038
#7 Post by JonW » Thu Mar 07, 2013 7:19 am
love this! nice work, looks great.
My Projects:
see them all at www.2smoked.com
82 RD 421 LC Hybrid
82 RD 250 '51L' YPVS LC
83 RZ350 LC2 Resto
Like Watches? Try www.PloProf.com and www.DeskDivers.com
Ricino
#8 Post by Ricino » Thu Mar 07, 2013 8:43 am
Very nice bike! A nice palette of Classic Yamaha colours!
It also makes sense the RGV swingarm and GP pipes combo.
Three months in your first build leading to those results is quite an achievement in my opinion.
crazydiablo
#9 Post by crazydiablo » Fri Mar 08, 2013 12:17 am
Love it.
1984 RZ350 YPVS 31K
1987 RD350 A/C
2009 Husqvarna SM610
dave_356
#10 Post by dave_356 » Fri Mar 08, 2013 9:47 pm
nice bike! thats exactly how i wish my rgv front was arranged, risers and dash and lights mounted on oem cowling. i can see a speedo sensor down there i need one of those too!
RZed
#11 Post by RZed » Sat Mar 09, 2013 2:42 am
Thanks for the great comments and all the advice I got from you guys on this forum!! :smt023
RZed,
Steve,
I tried to find some RGV parts without much luck, so I went with what I could find. And the stock shock was way too soft with the different linkage on the VJ23 arm.
Hooligan,
The swingarm bushings had to be narrowed .060" per side and bored out to fit the RZ pivot bolt. Then it slipped right in place. The SV rim worked using a GS 500 sprocket cush drive with a 10mm front offset sprocket.
Charlie
99 R1 USD front end
VJ23 swingarm
2018 XSR 900
petros67
#12 Post by petros67 » Sat Mar 09, 2013 4:24 am
Really nice bike :smt007 love it.
You gave me a nice idea on thoseTarrozi Hi-rise clipons , I will give them a try as these should be much more comfortable when riding compared to my RGV clip ons on my 421.
Enjoy that bike.
:smt006
Petros
This old RZ
#13 Post by This old RZ » Sat Mar 09, 2013 4:35 am
Nice bike, you made quick work of her! :smt023 Those are some OLD Toomey stickers on the tank.. I haven't seen those for years! I like the pipes, I also have a set.. the welding on those things are just beautiful to look at, those guys are metal artisans.
Regarding your r wheel, it seems that GS500 cush sprocket has a lot of uses,I have a FZ600 swingarm/ 1987/88 GSXR 4.5 rear wheel combo that utilizes that same GS500 cush setup. I didn't end up using it, but its all packed up in a box for the last 10 years...lol
Again nice bike enjoy...the ride :smt002
HAPPY 30th YAMAHA YVPS 350 1983-2013. DONT OVER THINK IT , JUST BUILD IT AND BE JUST AS FAST AND RELIABLE
kpke
#14 Post by kpke » Sat Mar 09, 2013 11:44 am
Yes to what everyone else said :smt023 :smt023 :smt023
Do have pics of "adapting" the stock upper fairing bracket to your setup?
It sure looks great :smt007
1983 rwb RZ350 Canadian stock (exc toomeys)
1985 rwb RZ350NC vm30,pods,porting,spec2 pipes
1985 yb RZ350 rat driver,fz/fzr parts,fox shock,vm30,pods,porting,toomeys
1985 RZ350 black? fz/fzr susp (in process)
more RZ350s on hold
1985 RZ500 (done, yah sure)
RZed
#15 Post by RZed » Sat Mar 09, 2013 1:07 pm
Nice bike, you made quick work of her! Those are some OLD Toomey stickers on the tank.. I haven't seen those for years! I like the pipes, I also have a set.. the welding on those things are just beautiful to look at, those guys are metal artisans.
Yes, I was running a set of the original Toomeys on my bike prior to this. Hence the "old" stickers!!
The SV 650 cush drive was about a 1/2" wider than the GS drive and wouldn't properly align with the front sprocket. Now the chain just clears the tire. (150/17)
It sure looks great
Thanks, I will try to take a few pics of the bracket and post them for you.
Charlie
99 R1 USD front end
VJ23 swingarm
2018 XSR 900
