RZ Frame modified MOTO3 project
Road racing, drag racing, motocross, vintage - anything racing related discuss it here!
Re: RZ Frame modified MOTO3 project
#121 Post by MK » Sat Mar 04, 2017 8:26 am
I am using a Microsquirt in my RD350 and the biggest advantage is simply the huge userbase (i.e. a lot of forums to ask).
There's a couple of knock offs that'd share the same code like the Dutch http://www.efignition.com/" onclick="window.open(this.href);return false;
ulsterman
#122 Post by ulsterman » Sun Jul 30, 2017 3:46 pm
Sorry its been awhile but racing and getting ready to go to Northern Ireland not easy
Please see the picture links below now for my Facebook updated pictures as i can not post them on here
ECU is now complete but at first start up developed a problem but now being corrected so not long now fingers crossed
Also Swing arm and alot more lightened to finish weight and strength
https://www.facebook.com/photo.php?fbid ... =3&theater" onclick="window.open(this.href);return false;
ulsterman
#123 Post by ulsterman » Sat Sep 16, 2017 6:03 pm
https://www.facebook.com/javajo44/video ... =3&theater" onclick="window.open(this.href);return false;
First start up with new ECU for the Moto3
So much more to do but heading in the right direction
Running with the low pressure direct injection into the barrel
ulsterman
#124 Post by ulsterman » Sat Oct 14, 2017 10:07 pm
Above is a link as most of the original Moto3 pictures have gone of this site and hopefully brings most people up to 2017
The motor as a direct injection four stroke has started up on "Zoltans" ECU and trying to fix the cold start up issues with the temp sensor
Big thing is this is a major step forward and next is to get it to accelerate fully
Then it will be to remove the carb and replace with 2nd exhaust and accelerate with fuel only and last back to the 3 stroke configuration
The 2nd link is from the RZ400 project and its been a tough year with it forsure
Thanks for following
Laird
ulsterman
#125 Post by ulsterman » Wed May 09, 2018 11:07 pm
https://www.facebook.com/laird.shinglet ... 483937009/" onclick="window.open(this.href);return false;
Been a while and been a tough winter for me with this project
ECU guy went his own way so i purchased an Ecotrons unit and installed it ---3 stroke still not running but go as far now as the direct injection into the barrel running --Alot more to come in next two to 3 wks
Questo vecchio rz
#126 Post by Questo vecchio rz » Mon May 14, 2018 1:55 am
Good glad to follow your projects ?
ulsterman
#127 Post by ulsterman » Sun May 27, 2018 6:10 pm
https://www.facebook.com/laird.shinglet ... 540797009/" onclick="window.open(this.href);return false;
ulsterman
#128 Post by ulsterman » Sun May 27, 2018 6:12 pm
https://www.facebook.com/laird.shinglet ... _processed" onclick="window.open(this.href);return false;
#129 Post by Smoker » Sat Jun 02, 2018 12:22 pm
Very interesting work!
Thanks for sharing.
ulsterman
#130 Post by ulsterman » Wed Jun 13, 2018 11:45 pm
https://www.facebook.com/laird.shinglet ... 009257009/" onclick="window.open(this.href);return false;
Ready for first time at the race track this weekend
Not the big race engine yet but it is getting there
ulsterman
#131 Post by ulsterman » Tue Jun 19, 2018 3:31 pm
https://www.facebook.com/laird.shinglet ... 396662009/" onclick="window.open(this.href);return false;
Made it out to the track this weekend
The bike frame and setup and the swing arm turned out all really good ---Motor needs a lot more work but getting there
T.RexRacing
#132 Post by T.RexRacing » Tue Jun 19, 2018 5:52 pm
Thanks for sharing this journey. It's been most enlightening.
Salvador Dali
ulsterman
#133 Post by ulsterman » Tue Aug 07, 2018 10:33 pm
https://www.youtube.com/watch?v=CcY4zsN-4tk" onclick="window.open(this.href);return false;
Latest uploads
Removed the ECU and new one on order
So many problems with this company but the tech is in the right direction
ulsterman
#134 Post by ulsterman » Wed Oct 10, 2018 6:48 pm
https://www.facebook.com/laird.shinglet ... 774227009/" onclick="window.open(this.href);return false;
Well the Ecotrons ECU you let down so off it came and many many fuel injection trials done and now a new set of cams i made -Double lobed so opening and closing every time and can use throttle body injection -Now have a Microsquirt on order and will also use it for the Banshee/RZ big machine
JanBros
#135 Post by JanBros » Wed Oct 10, 2018 7:00 pm
ulsterman wrote: now a new set of cams i made -Double lobed so opening and closing every time and can use throttle body injection
:smt017
what good should they do :smt102
if it runs, you can race it !
