Seat, Fuel tank removal
Hey all I just bought a 85 RZ350 canadian edition, and i wanted to remove the seat and fuel tank and the blessed seat got me stumped can anyone help a newbie to motorcycles?
1985 Yamaha Canadian market RZ350RN <---- WIP
Needs a rebuild, and some paint and ALOT of TLC
ok thanks, im wondering is there an oil pump on the bike, i looked over a service manual and it never mentioned, but it said about an oil tanknokturnal wrote:2 latches to the back of the seat, kinda up behind the the tail. You will need a key for one.
Re: Seat, Fuel tank removal
READ THIS:jmichelin wrote:can anyone help a newbie to motorcycles?
http://www.edisucks.org/rz350/manual/RZ350L-N-NC.pdf
yah it does, and when i start my bike it feels like the kick start shaft inside is slipping thats a big job eh:(, i tried to remove the seat but i couldnt HAHA, is there a trick to it?? and the oil reservoir is under the seat eh lol,the previous owner added the oil to the gas, and she smoke heavy, what should i look for when i remove the oil pump cover?
- aaronmvrider
Yah im trying to find another cable, and now a new fuel tank, the idiots had a hole in it and patched it with fiberglass and resin, as well as silicone lolaaronmvrider wrote:get it fixed its easier in the long run
JB weld or a similar cold-weld two-part mix seems to work well on fuel tanks. Mine had about a dozen rust pinholes and a couple larger ones and I just sanded it down to the metal, roughed it up with a wire brush and JB Welded it. Had a slight leak so I sanded the JB weld smooth and applied another coat. Works perfect now.
Kevin
Kevin
1982 RD350LC
2018 Husqvarna Svartpilen 401
sweet i just laid a bit on my tank and smoothed it out by finger, later on ill sand it then lay a bit more on and see what happens if alls good ill repaint the whole bike, thanks for the help guys, the stuff i got is a steel putty thingy i got from a friends father it said you can sand and grind on it even
