RZ350 Super Motard
Re: RZ350 Super Motard
#991 Post by Smoker » Fri Aug 24, 2018 2:24 am
Got the exhaust tips welded.
Ready for pipes.
The exhaust tip tubing was slightly larger. Was harder to weld that bead because of a small gap.
#992 Post by Smoker » Fri Aug 24, 2018 9:22 pm
Exhaust tips and mufflers are fitting well.
Removed it as a unit. Solid as a rock.
#993 Post by JonW » Fri Aug 24, 2018 10:12 pm
nice!
#994 Post by Smoker » Sun Sep 16, 2018 4:39 am
Got the info. Will be delivering the bike soon for pipes by Jeff Henise.
Hope it works out. Still worried about ground clearance with down-pipes, and don't want the heat from up-pipes. No good answer.
Price is what you'd expect, if you saw Jeff's resume (link previously posted). Last project I saw him build was that world record setting land speed bike, a few months ago.
Latest decision for pipes is stainless with full polish. Stingers will be full polish stainless, with gold titanium nitride coating. Annealed titanium pipes would be too colorful with this engine, and the rotor side engine cover is full polish aluminum.
#995 Post by Smoker » Tue Sep 18, 2018 9:02 am
About 6 months ago, I gave the machine shop info to make threaded connectors for the pipe stingers.
Guess they're not gonna do it. I've asked a few times, and they always say they will.
Stayed up all night and drew some nice slip-joint connectors. The spring eyes are machined, instead of welded on, and they use an o-ring. Need to have springs before I can finish the drawings. Will try to order Akrapovic springs today.
Could also machine up some similar pieces to use on the header pipes.
Should have this done already. Want to deliver the bike soon.
#996 Post by RuZty » Tue Sep 18, 2018 9:17 am
You can also get nice exhaust springs from Burns Stainless; https://burnsstainless.com/collections/ ... ess-spring" onclick="window.open(this.href);return false;
#997 Post by Smoker » Tue Sep 18, 2018 9:27 am
RuZty wrote:You can also get nice exhaust springs from Burns Stainless; https://burnsstainless.com/collections/ ... ess-spring" onclick="window.open(this.href);return false;
Cheap, too.
Too bad they don't list the size of the spring. Very strange.
Will be using 60mm springs (with vibration dampers). :smt023
#998 Post by Smoker » Fri Sep 21, 2018 1:00 pm
Redesigned the pipe layout.
Got rid of the crossover pipes. Chose symmetry over the novelty and slight performance advantage of crossover pipes.
Had to shorten up the pipes, crossover of not.
Still needs some adjustment.
#999 Post by Smoker » Fri Sep 21, 2018 6:52 pm
Suter MMX500 springs.
Gotta be good, right? :smt003
#1000 Post by Smoker » Sat Sep 22, 2018 2:39 pm
#1001 Post by Smoker » Mon Sep 24, 2018 12:03 pm
Drove from L.A. to Frisco and back, yesterday. [Brutal!!]
The SXZ is now at Jeff Henise's shop. With the current Land Speed Record bike. :smt003
Jeff is definitely one of the most interesting motorcycle dudes I've ever met.
When I get a minute, I'll post some of the amazing stuff I saw.
#1002 Post by JonW » Mon Sep 24, 2018 7:19 pm
Great progress Smoker. :)
Moderator
Moderator
#1003 Post by silverstrom » Mon Sep 24, 2018 7:35 pm
+1 That looks brilliant.
Moderator
Moderator
#1004 Post by silverstrom » Mon Sep 24, 2018 7:39 pm
Smoker wrote:Drove from L.A. to Frisco and back, yesterday. [Brutal!!]
850 miles...that's quite a hike Pete.
#1005 Post by Smoker » Wed Sep 26, 2018 10:26 pm
Trying to measure exhaust port duration. Prefer not to remove the head to check the deck height.
Made a quick degree wheel. Flashlight through the plug hole; looking through the exhaust port.
