My Blinged-Out RZ Project
Re: My Blinged-Out RZ Project
#2026 Post by Smoker » Wed Oct 12, 2016 7:21 am
The top frame tubes are 1" OD.
So, I made a new template out of 1/2" stock (.475" actual) Then mounted it flush with the top of the upper bar.
Will secure the brackets to the template to make sure they're level and on the same plane before welding.
#2027 Post by Smoker » Fri Oct 14, 2016 4:12 pm
Brackets welded in for the first panel.
Also cut, welded and filed brackets for the next panel. Constructed a nice welding jig, but broke it down before the pic was taken.
#2028 Post by Smoker » Fri Oct 14, 2016 4:22 pm
Steering damper mount welded to the frame. Test fitted the damper, and the height and angle are good. Measuring now for a custom titanium pin.
Also welded the throttle cable cut-out.
#2029 Post by Smoker » Sat Oct 15, 2016 2:09 pm
Beginning of a custom kickstarter.
The tool is 1" x 1" aluminum. It fits tightly into the kickstarter hole with no play/movement.
With the tool in place, I can make accurate measurements from the axis.
#2030 Post by Smoker » Sun Oct 16, 2016 8:22 pm
Was starting to fit brackets for another panel and had a better idea.
The frame tubings have an angle. I was going to use a flat carbon fiber panel, but you can see how it fit in the photo. The left side of the panel is at the top of the frame tube, the middle is at the bottom, and the right side is back at the top. The flat panel is great for mounting stuff, but looks less than custom.
I want to use 2 carbon panels, joined at the tubing bend. Will custom bend a titanium angle strip or 2 (top and bottom) to bond the panels together. Aluminum would be lighter, but if I TiN coat the strips, they'll match the panel hardware.
Just need to find out how thin I can go on the titanium for TiN coating.
yazza54
#2031 Post by yazza54 » Fri Oct 21, 2016 11:47 am
Nice Work
#2032 Post by RuZty » Fri Oct 21, 2016 8:01 pm
Make a carbon panel with a bend in it, it is well within your abilities. You could also join two flat panels nicely without tons of effort if you don't care too much what the back side looks like.
#2033 Post by Smoker » Sat Oct 22, 2016 3:50 pm
RuZty wrote:Make a carbon panel with a bend in it, it is well within your abilities. You could also join two flat panels nicely without tons of effort if you don't care too much what the back side looks like.
Thanks. I did think about making an angled carbon panel- but then I would have to make all 3 panels, in order for them to match.
You know I care what the backside looks like. I love a good backside!
I don't think bending a strip of titanium is going to happen. Looks like I'll need 2 machined parts. Probably just a few bucks worth of titanium. And some machining. And some titanium nitriding. :smt003
Just received some rubber trim for the fuel tank. Will see if I can use something similar on the panels.
#2034 Post by Smoker » Thu Oct 27, 2016 6:37 pm
Getting better at making rigs and jigs to hold parts.
#2035 Post by Smoker » Thu Oct 27, 2016 6:38 pm
Tacked the steering lock stop.
A while back, I remade the custom steering stop. I made the spacing perfect to the frame, but when I fitted the fuel tank, the spacing was a little off. I forgot about the lock stop. When I went to tack in the lock stop, it didn't fit anymore. Shaved both sides of the lock stop a few times to get the fit right, again.
Went through three different types/sizes of wire to get a good hold. Using 1mm stainless wire, threaded through the frame and headstock.
Next, TIG brazing the lock stop, so the head tube doesn't distort from welding.
#2036 Post by Smoker » Sun Nov 13, 2016 10:35 am
Titanium pin for mounting the steering damper. Needs polishing and gold titanium nitriding.
Also need to order proper titanium hardware.
#2037 Post by Smoker » Wed Feb 15, 2017 5:57 pm
Welded a bung onto the battery box to hold a rubber grommet. The mounting bolt head sits inside the bung, under the battery.
Next, need a machined collar/spacer to fit under the grommet.
#2038 Post by Smoker » Sun Feb 26, 2017 5:57 am
This sweet little bracket was cut from a steel bar.
To be welded to the frame for securing the battery box.
Now the bad news. Of course, I fucked it up because I can't make anything right the first time.
The hole lines up perfectly with the upper hash mark. Unfortunately, it's supposed to line up with the lower hash mark. Incredibly stupid on my part.
I could just weld the bracket on the battery box 1/2" higher and use the steel frame bracket. But then, my artistic vision for this piece would be lost. :smt003
The battery box bracket should be the same distance from the bottom that the strap bracket is from the top. (And both brackets should be the same width.)
Damned artistic vision costing me time and money.
#2039 Post by Smoker » Wed Mar 01, 2017 6:01 am
Made a spacer for the battery box.
Still need to clean up and polish the box.
#2040 Post by hondaror » Wed Mar 01, 2017 10:16 am
Love your attention to detail. Great work as always!
