I know I'm being lazy and could put a degree wheel on the crank and measure the piston travel with an indicator but I believe there was a conversion chart published on this forum some time ago, does anyone have it or know where I can find it?
Thanks, oldracer
Crankshaft degrees-piston travel
Thanks beebe, this is exactly the information I am looking for. Could you let me know the linear measurement, (piston travel) for: 24,22,21,18,17and 9 degrees before T.D.C.
I have a Motoplat ignition which does retard the timing as the revs increase, according to the strobe light anyway, and I want to put some scribe lines on the rotor in order that I can see where the spark is occuring in comparison to the chart in the shop manual.
Thanks again,
oldracer.
Thanks again,
oldracer.
