Sorting the Canadian RZ
Re: Sorting the Canadian RZ
Duplicate post
Tim Steele in Front Royal, VA
I dragged out my roll around build shelf and cleaned it up. I have the new parts organized. 108 days until Deals Gap 2023. I gotta get rolling.
url=https://postimg.cc/T5brj3fH][/url]
R6 cooling fan mock up in progress. Not too bad a job. Just takes time.
I use one Adel clamp and a frame tab on the other side adjacent to the coolant recovery tank. Still fiddling with the brackets. Ran out of play time and had to get ready for work. I also took the throttle tube and housing back off for lubrication. I sprayed the inside of the throttle tube with silicone spray and gave the cables a good dose of Dri-Slide. All in all a very productive morning. 60 days till Deals Gap
The Canadian 26mm carbs are fantastic. I’ve never felt a need to increase the size of the carbs on my RZs. This is especially so if you are riding the bike on the street.
I run my bikes with pipes and K&N pods: 56 wheel hp with stock barrels.
Thanks Rory. I have them and I may end up putting them back on.
https://youtu.be/-V3XEokpGs8
More progress. Run up for leak checks and verified oil pump operation. No leaks noted.
