Reed Valve Assembly Install
Moderators: rztom, 2smoke
2cycle
#1 Post by 2cycle » Mon Jan 14, 2019 10:39 am
Does it matter which way the valve assembly is installed into the cylinder? The manual says to use the corner of the valve stop that is nipped off for reference so its on lower left corner when installed but the lower left corner is always nipped off because there's one valve stop on both sides that has a corner nipped off.Hope that makes sense.
1973 ct70
1974 xr75
1977 rd400
1981 rd350lc
2002 zrx1200
justind97
Re: Reed Valve Install
#2 Post by justind97 » Mon Jan 14, 2019 3:07 pm
install them so any slight curve is towards the reed block. After the petals are installed, hold them up to the light and look through the intake for light. Should be none.
2cycle
#3 Post by 2cycle » Mon Jan 14, 2019 4:56 pm
Thanks Justin but i'm talking about installing the actual valve assembly that fits into the cylinder. I edited my post, hope it make more sense
1973 ct70
1974 xr75
1977 rd400
1981 rd350lc
2002 zrx1200
