I needed a crossover tube for an RZ project (The original was dented) so I bought a whole set of reed cages, boots, and crossover on eBay. I want to relist the reed cages and boots but I don't really know what I have here. These cages supposedly were pulled from a running 1985 RZ350. But they have 3-petal reeds. Anyone familiar with these?
The inlet hole on the carb side measures 50mm wide and 35mm tall
The triangle reed landing extends 40mm from the cylinder/reed cage gasket surface and is 54mm wide x 47mm high.
The stock boots line up.
Reed Valves what are these?
- Unknown Reeds - any ideas?
- IMG_2265Unknown.jpg (106.39 KiB) Viewed 645 times
Re: Reed Valves what are these?
FMF
http://www.erlenbachracing.co" onclick="window.open(this.href);return false;
