I used mapp gas, and I think you can even do it with propane. It does need to get fricken hot.
So - first ride is done. It's stiff. Very stiff. Damping feels good - never harsh and feels controlled. I would use straight 15W if I did it again (Maxima) because the rebound is a touch fast. I can still bottom it out under hard braking and sag looks good, but it has now exposed that my shock spring is too soft in comparison.
I think once I bump the shock spring up 10% it'll be more balanced and better overall. The shock spring is currently only about 5% stiffer than stock and we know the stock setup is very soft. Shooting for a 650lb/in rear spring now. (I'm about 195-200 geared up)
