Hello,
has anyone had plates made to fit the 1985 RZ U.S frame to accommodate a different set of resets? I want to use the 04-06 R1 rear sets (or possibly another) and thought about having an alum plate made to fit the frame to accommodate the rear sets. I have an after market set now, but I don't like how close the shift and brake pedal are to the pegs. Has anyone thought about making a few sets for sale?
Any assistance would be nice!
Thanks,
BA
Rear Sets
Re: Rear Sets
Hey BA, the downside to other rearsets is that it leaves you to come up with another means to hang the rear of the exhausts. I took a lot of excess metal off a set of late model RZ rearsets and was happy with the outcome, see here about half way down; viewtopic.php?f=5&t=15536&start=15" onclick="window.open(this.href);return false;
There were also the ones made by T10 a few years ago but I believe they have been discontinued. viewtopic.php?f=2&t=10348&hilit=rearset ... &start=375" onclick="window.open(this.href);return false; I also have a set of these still in the box and you have reminded me that I should try them.
Re: Rear Sets
I had a set of 08+ Honda CBR600rr rearsets mounted to an Rz. Actually worked out pretty well. 1 single plate, I used 1/8” flat bar, went to both mounts and the rearsets mounted to the bottom hole and a new drilled hole in the flat bar.
Exhausts we’re mounted with the same flat bar attached to the back side of the foot peg.
Re: Rear Sets
justind97 wrote:I had a set of 08+ Honda CBR600rr rearsets mounted to an Rz. Actually worked out pretty well. 1 single plate, I used 1/8” flat bar, went to both mounts and the rearsets mounted to the bottom hole and a new drilled hole in the flat bar.
Nice, Do you have any photos you can email me?
Thanks,
BA
baldanthony1@gmail.com
Re: Rear Sets
Email sent Anthony
