Hinson clutch and straight gear set
Posted: Sun Apr 01, 2018 1:07 pm
has any one tried the Hinson Clutch kit
I was particular looking at the straight cut gear set with the there hinson basket
I am not using the oil pump ,, I am blanking off
Also have all ready install the two stroke crank shaft and TZ roller bearings .. with the groove cut out on center bearing
or should I make my own gear set......
or do you know where I can get just the straight gear set
thanks
thanks
