Page 1 of 2
question regarding RZ350 locks/keys
Posted: Thu Jul 20, 2017 6:29 pm
by garcenw
I have a US 1984 RZ350 whose restoration is down to the little details. My key works in the ignition lock cylinder and the gas cap lock cylinder, but not in the helmet lock cylinder. Looking at the keyway, the helmet lock cylinder is that of another key code. Did the bikes originally have all three locks on one key or did the helmet lock use a different key?
Thanks.
Re: question regarding RZ350 locks/keys
Posted: Thu Jul 20, 2017 6:31 pm
by Disco
Should be one key. Your helmet lock is probably a replacement. There is a way to change the barrels out so they fit, but someone else would need to pass along that info.
Posted: Thu Jul 20, 2017 6:40 pm
by garcenw
That was my plan assuming they are supposed to be all keyed to a single key. I bought the "project" bike off someone else, so I don't know the history of all the parts. I'll need to source an "A" key code helmet lock cylinder.
Posted: Thu Jul 20, 2017 9:47 pm
by JonW
so long as the barrel takes the same key you can adjust the tumblers to get your key to fit, its simple but fiddly to do.
Posted: Thu Jul 20, 2017 10:30 pm
by JonW
Posted: Fri Jul 21, 2017 10:05 pm
by garcenw
That is my issue, i.e. the keyway is not the same which is why I posted for a type "A" lock cylinder in the "Want to Buy" forum. The keyway in my helmet lock is for an "C" or "E" type key.
Posted: Sat Jul 22, 2017 4:34 am
by JonW
thats why i posted the pic, i was trying to help since few people know about these key differences... I guess im not helping so i'll leave you to it.
Posted: Tue Jul 25, 2017 3:27 pm
by garcenw
Jon, we are both helping others with our comments. I was just further clarifying what the issue is as it is a subtle difference and your pic better shows the issue.
Posted: Fri Jul 28, 2017 5:06 pm
by evan_calgary
How does one tell what style the lock is without the key? I have a few but they are all missing keys.
Posted: Fri Jul 28, 2017 6:16 pm
by garcenw
Look down they keyway and try to match the shape of the slot to the pic Jon posted.
Posted: Fri Jul 28, 2017 6:20 pm
by garcenw
A and B are the easiest to discern and are mirror images of each other. C and E are similar as are D and F and may be harder to tell apart.
Posted: Fri Jul 28, 2017 6:25 pm
by garcenw
If you have an original key that fits a given slot (even if it's not the particular key for that lock), the key code is on the key. The first letter of that code is the key/cylinder type.
Posted: Fri Jul 28, 2017 9:39 pm
by Zedixe13
Under the ignition , there's a number with a letter , same for the helmet lock .
Posted: Sat Jul 29, 2017 6:17 am
by JonW
Zedixe13 wrote:Under the ignition , there's a number with a letter , same for the helmet lock .
not on any of mine :( you sure thats not something the earlier models had?
Posted: Sat Jul 29, 2017 12:48 pm
by Zedixe13
The key number is present on the ignition lock only ( sorry for this mistake ) , you probably have a pattern lock if there's no number .
