Picking Up My 1984 RZ-350 Project Bike This Weekend
Re: Picking Up My 1984 RZ-350 Project Bike This Weekend
Question:
Having a hard time locating a replacement tachometer cable for my 84.
Finding replacements for the speedo is easy. Would the speedo cable work as a tach cable?
2015 Yamaha FJR
Setup for multistate riding
2010 BMW F650GS
My dual sport bike
Finished Rebuilding - Restoring My 1983 RZ350
Rebuilding a 1980 BMW R65 with my daughter
It will be her bike when we're all done
2010 BMW F650GS
My dual sport bike
- Evans Ward
Parts Fische shows it is still available at around $13.25 from your local Yamaha dealer.
I just love the knowledge base of this forum.Evans Ward wrote:Parts Fische shows it is still available at around $13.25 from your local Yamaha dealer.
Thanks for the info.
2015 Yamaha FJR
2010 BMW F650GS
My dual sport bike
2010 BMW F650GS
My dual sport bike
UPDATE:
Haven’t been able to spend much time on the RZ lately. However, I did manage to get the frame powder coated and assembled it into a bit of a “Roller” this last weekend. I wanted to get into a roller so I can install a few parts on her as I get time.
Now I’m trying to figure out where all the electrical goes. (remember, I picked this bike up in pieces)
Any help I can get on where the components are to be located would be ULTRA helpful. Thanks.
2015 Yamaha FJR
2010 BMW F650GS
My dual sport bike
2010 BMW F650GS
My dual sport bike
Motor installed.
Still lots to do but it's getting closer.
New pistons are always a good thing.
2015 Yamaha FJR
2010 BMW F650GS
My dual sport bike
2010 BMW F650GS
My dual sport bike
Looking good and good to see a project moving forward..
Powdercoat excellent I'm a big fan of it at do it at the start of every project.
Don't forget to get that transfer pipe and hose between the reed intakes in position before you do anything else. Top rad filler junction and top hoses, coil, wiring loom in that order follow.
I'm a plus one fan of the Australian Canada 83 31k colours.
If I livid in Canada I would try and get a job as a posite just to drive the truck, I love those colours.
Keep at it, your doing a great job.
81Rd350lc resto 2016
81 Rd250lc resto 2017
1999 ZRX 1100
1999 ZRX 1100
Thanks for the information on assembly order. That will help heaps.seahorse wrote:Looking good and good to see a project moving forward..
Going to re-do the wiring loom. I have most (if not all) parts and connectors. I laid the wiring out a couple weekends ago and it seems that I have the basic lay-out figured. With the aid of my shop manual it should be done proper.
Cleaning and bead blasting the carbs tonight and tomorrow.
Love this project and the process.
2015 Yamaha FJR
2010 BMW F650GS
My dual sport bike
2010 BMW F650GS
My dual sport bike
Where does this fuel line go to?
Is it an overflow for the petcock?
2015 Yamaha FJR
2010 BMW F650GS
My dual sport bike
2010 BMW F650GS
My dual sport bike
Right hand carb, on the inside.
Jess
Jess
So that line feeds fuel to the right carb?Jessy wrote:Right hand carb, on the inside.
Jess
That carb gets fuel from the crossover line between them, correct?
2015 Yamaha FJR
2010 BMW F650GS
My dual sport bike
2010 BMW F650GS
My dual sport bike
That is a vacuum line which activates the flow of fuel when the Pistons move, creating a vacuum in the diaphragm.
The crossover rubber line is for the "choke" enricheners. The larger spigot is for the fuel, which Ts off to each carb.
Rory nailed the connections. There is a Prime function for starting, lets the juice run free.
Rory, JonW,
Here are some pictures of my carbs. Accroding to the guy I purchased this bike from, these carbs came off an RD400.
Do I attach the hose from the inside of the right carb to the fuel petcock.
Seems that the hose from the inside of the left carb is from the same area inside that carb too.?
I injected air into both those hoses and the air came out from the needle valve stem.
If that's the case I think I need to put a "T" in those hoses and then attach it to the petcock.
Confused for sure.
Confused for sure.
2015 Yamaha FJR
2010 BMW F650GS
My dual sport bike
2010 BMW F650GS
My dual sport bike
Those carbs do not have a vacuum line spigot. You have two options: 1). Drill a hole on the intake side of the carb, not the air box side, (only one carb) and press in a spigot to hook up a vacuum line to run to the petcock. 2). The easy way, buy an RD350LC fuel petcock or equivalent. Perhaps a non vacuum high flow Pingle, and install that.
Those carbs need a sonic cleaning. The stains near the air holes and plugs are what tells me that.
Rory,
Thanks. Just ordered my new RD350LC petcock.
Just one more reason this forum rocks!
2015 Yamaha FJR
2010 BMW F650GS
My dual sport bike
2010 BMW F650GS
My dual sport bike
