CAN 1983 RZ350
- OldTZracer
Re: CAN 1983 RZ350
In Canada the 17-digit VIN came into effect April 1st of 1983 and the first batch landed here just prior. I have '83 RZs with both 9 & 17-digit numbers. The popularity of the RZ combined with the carnage of Lightweight Production racing means there's probably more than a few with new frames out there...
Rocket Motorcycles was a non-franchised shop that turned out some fast bikes in its day. Sadly both Robbie Meiklejohn & Ron Lafavre have passed away at far too early an age.
Re: CAN 1983 RZ350
For the pipes, I decided the I'm going to leave them Stainless... no black paint.
In doubt, full throttle!
1971 Kawasaki F8
1983 RZ350
2002 BMW R1150R w/sidecar
2012 Ducati Monster 1100 EVO
2014 KTM 150SX
1994 TZR350
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
Re: CAN 1983 RZ350
OldTZracer wrote:In Canada the 17-digit VIN came into effect April 1st of 1983 and the first batch landed here just prior. I have '83 RZs with both 9 & 17-digit numbers. The popularity of the RZ combined with the carnage of Lightweight Production racing means there's probably more than a few with new frames out there...
Thanks for the info. It explain why the VIN is so short but a frame without any ID, never seen that.
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
Re: CAN 1983 RZ350
I am powder coating almost every parts on the bike. To do the job I want demand tremendous amount of patience and work. As an example, masking small detail with a tape and a razor blade::
EDIT: Changed from Dropbox to Google drive
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
Re: CAN 1983 RZ350
Carbs, ultrasonic cleaning and bead blasted. I finally like them!
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
Re: CAN 1983 RZ350
Master cylinder restored... still have to install the new glass.
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
Re: CAN 1983 RZ350
Master cylinder - close up on the letters.
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
Re: CAN 1983 RZ350
Engine head... tough thing to do the lettering in red with black powder coat, I am still not satisfied so I will redo it again for the 3th time...
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
Re: CAN 1983 RZ350
Pics still not working.
(Just want to see your good work!)
Re: CAN 1983 RZ350
What about now? I see them in my Browser.Smoker wrote:Pics still not working.
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
Re: CAN 1983 RZ350
They are in your dropbox account and require a login (which you have, hence you can see them).
Re: CAN 1983 RZ350
RuZty wrote:They are in your dropbox account and require a login (which you have, hence you can see them).
What about this... trying Google drive...
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
- two-stroke-brit
Re: CAN 1983 RZ350
What kind of drain screw is that ?tzrz350 wrote:Carbs, ultrasonic cleaning and bead blasted. I finally like them!
Re: CAN 1983 RZ350
Stainless steel allen screws. I am using them all over the place except where high tensile strengh is required.two-stroke-brit wrote: What kind of drain screw is that ?
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
Re: CAN 1983 RZ350
tzrz350 wrote:Stainless steel allen screws.two-stroke-brit wrote: What kind of drain screw is that ?
How did you put a point on the end of it?
