Can they be used as a tuning tool or is the 2 stroke too dirty to have a "clean" reading for any extended period of time? Where would be the best place to put the sensor? Was thinking of getting one of these LM-2 reader/datalogger.
http://www.innovatemotorsports.com/" onclick="window.open(this.href);return false;
And just saw this.
http://www.iwt.com.au/easitune.htm" onclick="window.open(this.href);return false;
Or is EGT still the best way?
Wide band O2 sensor and 2 strokes
REI
1989 TZR250 3MA
1988 FZR400
2003 R1
2008 WR250R
1989 TZR250 3MA
1988 FZR400
2003 R1
2008 WR250R
Re: Wide band O2 sensor and 2 strokes
From what I understand two strokes foul o2 sensors. I've heard of some "special" o2 sensors for dyno testing but they also are short lived. I use egt's with good results.
85 KR RZ350 ported W/Toomey pipes VM30's Air screw one 1/2 turn out/Main jet 240/Needle 2nd clip from bottom/6F5 jet Needle/159-P6 Needle Jet/40 pilot jet/2.5 Throttle Valve/2.0 Air jet
- steveloomis
What temperatures are considered a safe range, unsafe etc. I have been looking but do not know what to expect when tuning.
'81 RD350LC hybrid w/84 RZ engine. Zeel, Old style Toomeys, Yboot and filter 420 main 22.5 pilot, Air screw 2.5 turns out, DJ needle 2nd from top, Canadian VM26 carbs.
'85 KR/RZ US. Tank is seeping causing a blister in paint.....
Temps are very subjective, and can vary depending on location from the skirt. You are best to tune using dyno/plug chops and then establish a base line temp. But temps are considered safe below 1200*F Aluminum melts at aprox 1250* but I have personally seen higher temps @ 6" from the skirt with no problems. But my timing is stock 31k and an advanced timing may get a more thorough burn in the combustion chamber @ higher rpm, thus lowering the exhaust temp.
Smurph posted some stuff on O2 sensors in his thread on fuel injection,
http://www.rzrd500.com/phpBB3/viewtopic ... t=injected
Couple things from reading sled forums
1. WB sensors will last about a season(don't know how many hours that is?)
2. Too much heat will kill the sensor(above 1100f)
3. Will start to read lean as it gets contaminated(some mentioned cleaning with carb cleaner)
4. Innovative recommends placing the sensor in the can(because of heat issues)
Interesting. I have a Zeitronix ready to install. I use one in my Porsche 951 and am very happy, but fourstrokes are different and I would also like to know where to put the sensor. I would expect that putting it early would foul it with fresh gas overflow.
http://www.zeitronix.com/
F2 1986 project (ZX636R suspension)
F2 1987 The mule, test bench for tuning.
31K 1984 Donor
TZR 2MA 1986 Racer
TZR 2MA 1987 Stock
ZX10 1988 Cruiser
VTR 2005 (with CBRRR suspension, brakes and wheels)
Husaberg FS 570
GSX-R 1000 K5
31K 1984 Donor
TZR 2MA 1986 Racer
TZR 2MA 1987 Stock
ZX10 1988 Cruiser
Husaberg FS 570
GSX-R 1000 K5
I am fairly new to this board, but I thought I'd share my experiences. I have tried two different O2 sensor locations on my R5/RD350. The first time I tried it it was in the header section about 8" from the exhaust port outlet on the inner radius of the bend. This seemed to yield decent results for jetting above 4k rpm. Below 4k it seemed to get confused by the pulsing of the flow or the raw unburned fuel/air blowing across it. Years ago this helped me dial in the jets on my VM28's.
Most recently I tried the belly of the pipe on a very different setup. This yielded much more stable results, but I am guessing that due to on pipe/off pipes scavenging it seemed to lie to me at times. It is consistent, but you have to realize when unburned fuel and air moves across it it thinks lean, but it can mean rich. You can also have lean misfire and rich misfire which both can result in lean readings. I had times it was so rich like at the pipe anti-resonance (5500 or so) it misfired which resulted in super lean readings. The most believable area was when on the pipes and even then I had to resort to augmenting the tune by feel and plugs based on previous carb. jetting and O2 readings.
I am still in the process of tuning fuel injection and ignition advance on my R5/RD350 using a crank triggered 60-2 wheel, Electromotive TEC2, WRX injectors, and FZ6R throttle bodies using a MAP/TPS blend method so I had no "jetting" to start with. The WB is quite helpful but you have to understand its limitations especially on a 2-stroke application.
Eric
Eric
