I just did a top-end RE-build on my RZ350. All good.
The problem is I can’t remember where the hose from the fuel peacock vacuum outlet goes to? (It’s running fine when fuel set to prime but replaced all fuel hoses so no reference of length old hoses)
I guess it needs a vacuum so I guess somewhere on the carb to connect?
Can’t find anything about it in the workshop manual. Any suggestions much appreciated
Fuel peacock vacuum tube ?
Re: Fuel peacock vacuum tube ?
One of your carbs will have an extra hose barb. I don't recall if it's left or right carb. Hose goes from petcock to carb.
Ken's Garage
- OldTZracer
Not sure about the California models but most have a brass tube on the inside of the RH carb.
- Attachments
- RH carb.jpg (38.54 KiB) Viewed 675 times
You were correct On the inside of RH carb. Good to go now.
Many thanks for the tech knowledge
Right-side carb has the vacuum barb on US model joined carburetors as well
85 RZ350 daily rider Toomeys, FZ swinger & wheel, Fox shock, Raasks
85 RZ350 JLs, FZ swinger, Katana rear & CBR929 front wheel, CBR600F4 forks & brakes
75 RD350 Ritter-tuned top end, PWK28s, JLs, HPI, TDR wheels, GSX-R forks, Motolana swinger
