Shock bushing
emartinez
Shock bushing
#1 Post by emartinez » Tue Oct 17, 2017 2:25 am
What is the size of the bushing to get at mc master-Carr for the R6 rear shock on the rz
justind97
Re: Shock bushing
#2 Post by justind97 » Tue Oct 17, 2017 9:20 am
You need two 6659K36 Metric SAE 841 Bronze Flanged-Sleeve Bearing for 18 mm Shaft Diameter, 22 mm OD, 18 mm Length
You need two 6659K41 Metric SAE 841 Bronze Flanged-Sleeve Bearing for 20 mm Shaft Diameter, 24 mm OD, 16 mm Length
shilo123
Re: Shock bushing
#3 Post by shilo123 » Tue Oct 17, 2017 1:27 pm
justind97 wrote:You need two 6659K36 Metric SAE 841 Bronze Flanged-Sleeve Bearing for 18 mm Shaft Diameter, 22 mm OD, 18 mm Length
shilo123
Re: Shock bushing
#4 Post by shilo123 » Tue Oct 17, 2017 1:27 pm
thanks
