Picked this up last year for $600.00 , Total basket case. 1984,
Picked up a complete RGV250 banana arm, with wheel, shock, caliper, hugger etc for $300.... What a deal.. :)
2001 R1 complete front end with clocks and wiring for $350.
I just finished rebuilding the engine, Ported cylinders, Wiseco .66mm pistons. 34mm Flat slide carbs. Welded and balanced crank, Machined and skimmed head, Squish band re-profiled, YPVS all rebuilt. Billet clutch. Banshee reed cages gutted out with TDR racing reeds. Every bearing, seal and gasket replaced, Oil pump and water pump rebuilt.....
Forks, Stripped, cleaned, New seals, wipers and 5W oil and running lighter springs, Race Tech .85KG/MM rated.
Front brakes, stripped and cleaned, All new seals and pads..
Re-keyed the locks so they are all on the one Key, hate having a bunch of keys, they wreck the triples and bars...
RZ350, RGV, R1 Rebuild
Re: RZ350, RGV, R1 Rebuild
Wow, you did well picking all that up for $1250, nice project.
Nice man! I really like looking at flatslides
....So pretty....
...and the ones on my 1100 make a nice clickity clack
....So pretty....
Nice start of a project. Shame the tank is dented, it would be good to do a complete new running bike and keep the original patina panels and tank. The speedblock red is my favourite.
Check that you have room for the clutch cable under those carbs.
Find a higher profile rear tire.
81 RD 250 LC Hybrid .Widened frame with Aprilia RS250 Back end & Front end, strokd RZ 421, Kennys TSA's, 31KVM26SS Carbs M-360 P-25 ALBA Ndl Pos 3, Air 1.3/4
81Rd350lc resto 2016
81 Rd250lc resto 2017
1999 ZRX 1100
1999 ZRX 1100
