I've double posted several times by various mistakes.
However when I go to delete, I get a notice that states
" You can not delete posts from this forum"
Does anyone else have this issue?
I'm am logged in.. Also this forum underwent a (format) change what about a month or so ago.... the old screen is now different to view, is this also something' others noticed?
Deleting post issues? Anyone?
- Questo vecchio rz
Re: Deleting post issues? Anyone?
No problems with deleting, for me.
Just tried to make sure.
I have same issue Questo. I posted in members rides. When i pressed (submit post) it didn't upload, then after stuffing around it ended up in triplicate. Since i haven't been able to delete extra 2
yamaha fanatic.
I just tried and it worked fine.
I'm sure you know the deleting process, but I'll mention it for anyone new. You can only delete a post if it is the last post in the tread. You can edit any post at any time, but to delete a post it must be the last one. If anyone posts after you, you can't go back to delete yours, you can only edit it.
Graham, if you go to your last post and copy it and then delete it you can then delete your other 2 posts in order. Then post new again and paste what you copied.
Or...just ask the mods to fix it
