Page 72 of 86
Re: RZ350 Super Motard
Posted: Mon Jan 14, 2019 2:08 pm
by Questo vecchio rz
Wow, that just might be the( 1st full body nude image) we've seen of her.
She's looking pretty sexy, dude!
Posted: Mon Jan 14, 2019 2:31 pm
by mixalive
Hi. I am just now viewing your project. Very impressive. Can you tell me where you sourced the fuse box?
by Smoker
Questo vecchio rz wrote: βMon Jan 14, 2019 2:08 pm
Well, sort-of, but not really.
Correct pipes, frame, subframe & swingarm.
Other parts are mockup, for fabrication only. Engine, wheels, suspension, bars, clamps, black plastic, etc.
The tank could be interesting. Plan is one-off aluminum.
Posted: Mon Jan 14, 2019 2:35 pm
by tacky1
That is one sexy looking bike. Itβs really coming together
Posted: Mon Jan 14, 2019 2:36 pm
by Smoker
mixalive wrote: βMon Jan 14, 2019 2:31 pm
Source is my brain.
My own design. Had it machined from a block of aluminum.
If you mean the M-unit, they're all over the internet.
Posted: Tue Jan 15, 2019 10:45 pm
by Smoker
Don't recall seeing 1.25 inch OD stingers before.
Very happy with Jeff's advice.
Here, you can see the space for swingarm travel.
Posted: Wed Jan 16, 2019 1:19 pm
by mixalive
Smoker wrote: βMon Jan 14, 2019 2:36 pm
Source is my brain.
The actual fuse unit. I have not seen that one on the internet.
Posted: Wed Jan 16, 2019 1:56 pm
by Smoker
mixalive wrote: βWed Jan 16, 2019 1:19 pm
That's because you're a LAZY copycat.
The search engine is your friend.
Posted: Thu Jan 17, 2019 12:11 am
by Smoker
I have an mp4 file of the spring hooks being machined.
Can't post it on postimage.org.
Spring hooks are completed. Jeff will weld them when he comes back from Phillip Island.
Posted: Sun Jan 27, 2019 11:58 pm
by Smoker
Finished Spring Hooks.
4 radiused for headers.
4 radiused for stingers.
Posted: Mon Jan 28, 2019 12:10 am
by Smoker
Didn't know anything about electropolishing.
Jeff uses it for his science projects, and suggested it for the pipes.
Found a place, and trying to work out details. Got this response:
"304 and 316 both should polish up nice. I think it will be about $150 for all four pieces. Also, We will pre-treat the welds before we electro polish the entire part."
That's a lot of pre-treating!
I was worried it would cost more. It's in another league, compared to mechanical polishing.
Much safer in terms of accidental damage to the pipes. Should make a noticeable difference for gold nitriding the stingers.
Posted: Mon Jan 28, 2019 12:09 pm
by kpke
Posted: Mon Jan 28, 2019 12:16 pm
by Smoker
Nice!
Who made your pipes?
You're up that way... Advanced Electropolishing?
Posted: Mon Jan 28, 2019 5:32 pm
Smoker wrote: βMon Jan 28, 2019 12:16 pm
Nice!
Those are polished Lomas pipes...No?
Posted: Tue Jan 29, 2019 12:11 pm
by kpke
Questo, those are electropolished JL SS pipes.
Smoker, my pipes were taken to a vendor we use at work for humongous stainless steel enclosures, beam tubes, etc. I had to be careful having them do the work because with a government job you are not allowed to ask for favors.
I looked up Advanced Electropolishing. They are right in the heart of Silicon Valley. If Jeff uses them for his projects I am sure they are good.
Keep in mind if you want to have PERFECT mirror finish this may not be the way to go. The finish is quite beautiful but hair line surface scratches and other flaws will show up upon close inspection. Versus hand polishing where you can eliminate tiny little defects by sanding and polishing with varying degrees of grit. I am fairly picky and perfectly satisfied with the finish on these pipes. There is a certain amount of hand prep they will do at the electropolishing vendor however, they are not you, and will work to their standards however high or low that may be. It should be high at that place.
BTW, the finish has held up quite well on my 500 pipes.
