I wish I could but I dont have a wheel yet, I have measured more than once and so far all good, BUT if it does turn out to be out of line which I dont think it is then its and easy fix, just would need two spacers re-done or moded and put them in. BUT for the nc30 arm to go in an f2 frame square it would put the chain line out 5mm, and mine is bang on 5mm out.RGVSteve wrote:rdstars,
Is the wheel centered when its installed on the swingarm? Fitting a
single sided swingarm is not the same as a regular swingarm, I've
done a few just trying to save you some headaches. Humor me, fit
the wheel, mark the center, run a line from the steering head to the
wheel center stand back and eye ball it, if all is well, great, if not
better to find out now.
Wish I had all the parts in one go but its down to budjet and what turns up. Carnt wait for a wheel to turn up so I can be 100% and will post as soon as I can, it wasent on my mind untill now as I have taken load of measurements and sure its right. The nc30 frame is square between mountain points and the arm fits square inside, my rd frame is square between mountain points and the arm is fitted and spaced square.
Any chance you could do a write up on how you fit yours and what mods you do, be handy to see another way, do you mod the arm or the frame?
