kobra's 1985 RZ350NC2 basket case restoration
Re: kobra's 1985 RZ350NC2 basket case restoration
You can reuse OEM head gaskets, Ive taken mine apart 4 to 5 times and reused it and no probs, I spray a little copper spray and all good.
This is how I measure all my squish clearances, This way you get a more accurate measurement.
Well that's reassuring :)
Picked up some Permatex copper spray sealant today.
Okay, another question. The saga continues...
I pulled out the shift drum, shift forks, etc. so that they are not in the mix when I sandblast. Kind of a pain getting those phillips head screws out. I made sure to use heat first rather than risk twisting them, and also used a manual impact driver.
Anyway, I pulled the shift drum out and that needle bearing kinda feels like crap. It's not chunking but definitely doesn't feel smooth, and is pretty loose. The drum itself is not a polished bearing surface so the rollers feel gritty running over it. I noticed the other end doesn't even have a bearing. Now, how critical is this one? The drum basically just indexes with very little force on it, so maybe this is normal...
I would replace the bearing since you already have it all apart.
Yamaha shifting has always been kind of "notchy." Some others might describe Yamaha shifting as having a "positive" feel. After years of riding Yamaha's almost exclusively, the first time I rode a Honda while wearing boots, I thought I missed a shift because it was so smooth!
My point is that Yamaha obviously didn't think this was too important. The shift drum rides in an oil bath. The shifting action is always smoothest right after an oil change. Anything you can do to reduce friction there will make it feel better but you can only do so much to improve the action with out getting into custom work elsewhere.
Apparently the banshee guys will turn down the shift drum and put different bearings. They also replace the shift star follower with a bearing rather than the little jiggly roller that is stock, and these mods are supposed to tighten it up and smooth it out a bunch.brrrappp wrote: ↑Thu Jan 17, 2019 8:42 pm I would replace the bearing since you already have it all apart.
I stumbled on an old post here from JonW saying the stock bearing is nasty feeling even when brand new. Guess it doesn't matter too much... haven't heard of any failures because of it.
You can probably find lots of creative ways to lighten the action. Softer shift return spring, round the tops of the shift star, polishing or hi-tech coatings for the drum grooves, transmission shafts and shift shaft. I think someone even sells a kit to place a bearing in the case or case cover where the shift shaft rides.
I can feel a big difference (good) in shift action simply by running Bel-Ray light viscosity gear oil. I think it's now called Bel-Ray 80w GearSaver Transmission oil.
A really good mod is to grind the shift Star. I do this with all my bikes. Just google banshee shift star mod.
https://www.youtube.com/watch?v=as-48SLsPDs
Hrmm, I am wary of modding that shift star without ever riding it in stock form. To be honest I can't say I've ever had a problem with any bike's shifting except for my old BMW with a rotax motor - it wouldn't clutchless shift no matter what!
I do however want to replace these god-awful phillips head screws with some socket heads!
Couple random questions as I make progress...
-Should I lubricate the head studs that are installed into the cylinder? ARP says yes, but only with the correct lube. Seems to me like it would just help them from getting so stuck if this ever comes apart again, and won't affect torque spec during install.
-Is it recommended to gently sand the reed valve cages (rubber part) to improve sealing? I am installing TDR reeds. If so any tips on doing it right?
That is incorrect, when tightening a fastener most of your effort goes into overcoming friction in the threads and under the nut or head of the bolt. You will reach the specified torque at a lower clamping force (tesile load) in the fastener with dry threads. Lubrication reduces the friction, resulting in a higher and more consistent clamping force for the same torque. A bolt or stud will twist slightly under the torque (like a torsion spring), cyclic and thermal loading will allow that to unwind, hence the spec to retorque after a heat cycle.
I'm referring to the part of the stud that goes into the cylinder, which pretty much is fixed once you tighten them down. Seems like a tiny bit of some lube might keep them from seizing in there so bad. I don't plan on lubing the top threads or the nut for the exact reasons you mentioned.RuZty wrote: ↑Sun Jan 20, 2019 6:32 amThat is incorrect, when tightening a fastener most of your effort goes into overcoming friction in the threads and under the nut or head of the bolt. You will reach the specified torque at a lower clamping force (tesile load) in the fastener with dry threads. Lubrication reduces the friction, resulting in a higher and more consistent clamping force for the same torque. A bolt or stud will twist slightly under the torque (like a torsion spring), cyclic and thermal loading will allow that to unwind, hence the spec to retorque after a heat cycle.
I guess the question is...... does it matter if the stud loosens or becomes over tightened due to the lube.
Example: 1) when you go to remove the head retaining nuts and the stud comes out with the nut attached....
Example 2) When you torque the head nuts and the stud tightens further instead on the nut on the stud....leading to the threads in the cylinder being stripped.
Lube the threads of the stud before you install them in the cylinder. I usually coat the first 1/4 of the total length of the threads. I use motor oil or anti-seize.
If your stud comes out of the cyl. when you loosen the nut, that tells you that someone never tightened the studs tight enough, or the head nuts have galled. If the stud tightens in the cylinder when tightening the head bolts, you have not tightened the stud enough. The stud will bottom out in the threaded hole in the cylinder when you tighten it.
The head is only torqued to 18 ft. lbs. Not like your are torquing on a 429 CJ Ford head.
Put a small dab of oil on the head bolt flange that faces the washer and the threads. Much more constant torque.
2.5 RZ350's
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
Good read on how and why fastener torque.
https://ridermagazine.com/2005/11/15/th ... fasteners/
basically it says
Oil yes.
No Synthetic or heavy oils, molly paste, teflon.
Too slippery = too high a torque value. No lube might lead to not enough.
basically it says
Oil yes.
Pretty sure torque specs are called out as clean and dry unless otherwise specified!
Been tweakin out more trying to decide which screws to buy. I'd like to buy from McMaster since I can get exactly what I want, but the only downside is I end up with 25-100 of each thing. So the idea with this is to determine which screws can cross over in terms of length and style so I can use the same screws in several areas.
A lot of the screws are rusted, stripped, or missing, and some I want to replace simply because socket heads are nicer than phillips in most cases.
Here's the chart so far. If I have the energy to flesh it out it might be a useful contribution to the forum.
