New LC project
2smoke
Moderator
Re: New LC project
#31 Post by 2smoke » Mon Aug 20, 2018 11:19 am
Does the bike still have the original fuse box?
If so the culprit may be in there.
The speedo drive may need grease or a new cable. Or the bearing in the speedo gauge could be shot.
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
Hooligan
Re: New LC project
#32 Post by Hooligan » Mon Aug 20, 2018 1:47 pm
The mechanical drive speedo in my FZ made weird whirring noises and the needle would jump up and down erratically. A replacement cable didn't solve the problem. One day the thing made a whirring-shattering noise and the speedo needle blew off its mount. The odometer drive kept working for a while after than and then also quit.
In the end I tracked the problem down to the plastic drive gear in the front hub. Yamaha made the drive gear out of plastic but does not (and never did) offer that gear as a replacement part. I managed to find a metal replacement gear at a local shop.
I also had to find a replacement speedo at great cost.
If your speedo is making a weird noise, the first thing I'd check would be the speedo drive gear.
Hooligan
Re: New LC project
#33 Post by Hooligan » Mon Aug 20, 2018 1:48 pm
I am stymied as to how an electrical problem could affect a wholly mechanical tach drive system?
nokturnal
Re: New LC project
#34 Post by nokturnal » Mon Aug 20, 2018 2:13 pm
is it wholly mechanical? looked like there were wires and a coil if I remember correctly... was a bit of a blur taking it apart. I was mainly focused on the idiot light wiring/ground
:smt017
Hooligan
Re: New LC project
#35 Post by Hooligan » Mon Aug 20, 2018 2:19 pm
The tach drive is completely mechanical on an LC. The wires are for the illumination bulb.
The tach on a second gen RZ is electrical. Not sure about the first gen RZ but I'd suspect it is also mechanical.
AlexG
Re: New LC project
#36 Post by AlexG » Mon Aug 20, 2018 2:28 pm
The tach and speed meters are mechanical on my 84 RZ. Tach cable routed in between the two carburetors.
nokturnal
Re: New LC project
#37 Post by nokturnal » Tue Nov 13, 2018 10:04 am
Late model RZ engine and peripherals aquired for hybrid transplant. Stay tuned.
:smt017
nokturnal
Re: New LC project
#38 Post by nokturnal » Mon Nov 26, 2018 10:04 am
:smt017
nokturnal
Re: New LC project
#39 Post by nokturnal » Sun Dec 02, 2018 6:52 pm
Slipped er in when no one was lookin
:smt017
Re: New LC project
#40 Post by RuZty » Sun Dec 02, 2018 10:12 pm
Nice. Open it up or run as is? Carbs?
nokturnal
Re: New LC project
#41 Post by nokturnal » Sun Dec 02, 2018 10:31 pm
Gonna roll the dice if the compression checks out...
LC carbs. Dumped over $100 in new needle/seats so not going to toss those any time soon.
Do need some switches tho... final piece of the puzzle...
:smt017
nokturnal
Re: New LC project
#42 Post by nokturnal » Sun Dec 02, 2018 10:43 pm
Think I need a clutch cable too..
:smt017
nokturnal
Re: New LC project
#43 Post by nokturnal » Wed Oct 02, 2019 12:04 pm
Not done with the RZ conversion...
Figured I would complicate matters by bringing another one into the room...
Will be a pick at it resto. Going to see if it runs this weekend.
:smt017
Re: New LC project
#44 Post by JonW » Wed Oct 02, 2019 6:10 pm
That looks pretty good.
