Newbie ,421 Cheetah
Newbie ,421 Cheetah
Hello People,
I am Val from Holland and new here on this forum.
Here is my project, as it is today.
31k Cases and Gearbox
Hotrods 4mm Welded Crank
Cheetah Cub 6858 (421cc)
Ignitech Ignition
40mm Keihin PWK
V-Force4 Reeds
Wicked Manifold
VTM Custom Build Pipes
RSV Mille Chassis
RS250 Fueltank
Ohlins Suspension
OZ Racing Forged Aluminum Rims
(YZR500 OWK Fairing and Seat on order)
Ignitech Ignition
40mm Keihin PWK
V-Force4 Reeds
Wicked Manifold
RSV Mille Chassis
RS250 Fueltank
Ohlins Suspension
Re: Newbie ,421 Cheetah
Hi Val, nice "gp" project. It seems that you are in the nautical branch. Are you going to make your own composit parts for the fairings and so on
Nice project!
What will you be doing with the bike?
- Questo vecchio rz
Quite nice project.
I like that frame /swingarm combo I remember it being reasonably lightweight. With a Ingitech and dual 40mm carbs, Looks as if you building a dedicated track bike ?
Are you rubber mounting the motor at the lower mounts?
Did you opt for a billet clutch basket,not absolutely necessary but I'd suggest it as an addition. The. 421+ Cheetahs can be harsh on the stock basket.
What's your final sprocket offset, if any ? On my project, I'm not worried about offset too much as it's going to be a track day bike only. I really doubt I'll ever have a problem with it, It's to have uprated bearings+a shaft brace.
With the OWK variant bodywork, it's going to look very good, are you using MotoForzas product, or another vendor?
Anyways, yours looks as beautiful as it's likey to be functional??
Last edited by Questo vecchio rz on Sun Feb 11, 2018 2:22 pm, edited 2 times in total.
85 custom Tri-Z
RZ/YZR bike(project)
Royal Enfield Bullet 500
85 custom Tri-Z
Wow $$$$$
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
- two-stroke-brit
wow look at the rear rotor.
its more air than metal.
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
1982 YAMA RD350LC
98KDX 220R
1967 TRIUMPH TIGER
2001 TRIUMPH TT600
Thanx.:)Questo vecchio rz wrote:Quite nice project.
Indeed the bike is meant for the track, i have papers but i dont think the bike will be ridden too much on the road.
The sprocket offset 18.6mm the largest i could get.
Motoforzas yes , just hoping for nice quality, should be here next week.
See pics for the lower engine rubbers and the clutch....
Val : have this clutch basket and since here not able to use it ....clearance problem whit the mechanism with 7 plates and no place enough with 8 :-( let know if it mounts your side
Okidoki i'll let you know, probably within two weeks.Crimsondevil wrote:Val : have this clutch basket and since here not able to use it ....clearance problem whit the mechanism with 7 plates and no place enough with 8 :-( let know if it mounts your side
Bump
Anything new on this wild build?
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
two-stroke-brit wrote:wow look at the rear rotor.
That's what keeps drawing my eyes to as well !
