Low Budget Purple Project
Off Road
Re: Low Budget Purple Project
#1111 Post by Off Road » Tue Dec 01, 2015 2:52 am
Hooligan
#1112 Post by Hooligan » Tue Dec 01, 2015 2:59 am
I sent my oil pumps out to the UK to be rebuilt. It was def expensive but the pumps are now just as they would have come from the factory and the slow leak when the bike is not run seems to have stopped.
'85 FZ750
ddeford
#1113 Post by ddeford » Fri Dec 04, 2015 5:58 pm
I've been perusing this section of the forum to see how well the FZR400 forks bolt up, but I didn't see it immediately. Can you tell what was required? I have an RZ on the way (gift from my brother) and a full FZR400 frontend that I can easily buy. Before I buy the frontend, I'd like to know if it's pretty close to a bolt-up solution (or if you recommend something else).
Off Road
#1114 Post by Off Road » Tue Dec 08, 2015 3:28 am
On Dec. 5, 2009, I wrote my 1st post in the Low Budget Purple Project thread, and made the following statements:
Off Road wrote: Now would be a good time to work on my RZ350 project. No Wife, no Kids, no Boss. :smt014 , [smilie=baby.gif] , [smilie=director1[1].gif]
To be perfectly honest, I'm just not into it. At least not tonight.
Anyway, this seems like a good time to start a new project thread and tell everyone know about my BIG plans for a Project Bike
I'm going to post pricing on what everything cost. Let's face it. Most of us are interested in what other people are paying for RZ's.
Besides that, 30% of you will think I paid too much, 30% will think I got a screaming deal and 40% will think I'm lying about the price. lol :smt003
I'm also going to post a bunch of progress pics as well.
But, just to let you know, you're not going to see a lot of "high tech bling" and "one of a kind parts made of unobtanium" on this post. :smt012
The title accurately describes this Project "Low Budget"!
Hell, it hardly even qualifies as a "Project". It's more like few bolt-on parts and a couple of minor upgrades to the bike.
Well, it's taken me 6 years, but I'm finally getting close to accomplishing my goal.
I've got a frame and a motor, just need to start bolting it together.
But first, I had to install the center-stand spring. :smt013
JonW
#1115 Post by JonW » Tue Dec 08, 2015 3:41 am
It is said that a journey of a thousand miles begins with a single step... or spring :)
hondaror
#1116 Post by hondaror » Tue Dec 08, 2015 6:23 am
I love seeing these bikes saved and not parted out.
Off Road
#1117 Post by Off Road » Wed Dec 09, 2015 2:42 am
Got a bit done today, but not as much as I hoped.
Installed a new set of fork seal in the 85 forks.
I also installed a spare set of progressive springs that I had lying around.
I had to cut a 1" aluminum spacer, because the 85 fork tubes are longer than the 83/4 tubes.
When I started building this bike 6 years ago, I installed a new set of tapered steering bearings in this frame.
I pulled the triple tree's and checked them, and they look mint.
They should, they've never been outside the building.
Installed a pretty good, lightly used BT45 tire on the front rim.
(It's the tire I took off my track bike last week)
Just need to add some fork oil and screw the fork caps back on.
Greased the swngarm and linkage pivots, and got the swingarm re-installed.
While I was in there, I installed a Works Performance shock that I had kicking around.
I also installed a new 40T rear sprocket, and a new 110/80-18 BT45 rear tire.
Off Road
#1118 Post by Off Road » Thu Dec 10, 2015 12:44 am
Forks are finished and the bars are on. :smt003
Swing-arm's been removed due to a change in plan. :smt011
Moderator
Moderator
#1119 Post by silverstrom » Thu Dec 10, 2015 1:42 am
You might want to rethink that new front fender. Looks like it might be just a bit too close to the wheel :smt003
hondaror
#1120 Post by hondaror » Thu Dec 10, 2015 2:19 am
It needs paint too.
Off Road
#1121 Post by Off Road » Fri Dec 11, 2015 1:31 am
silverstrom wrote:You might want to rethink that new front fender. Looks like it might be just a bit too close to the wheel :smt003
Too Funny. :smt005
But you're right, I do need a front fender, and the brace that holds it in place.
You wouldn't happen to have a cheap, ugly, yellow fender for sale, would you?
Off Road
#1122 Post by Off Road » Fri Dec 11, 2015 1:34 am
In my collection of parts, I found a pretty nice 86 swing-arm.
Since it has bearings in the swing-arm pivot, and the 83 swing-arm has bushings,
I decided to pull the 83 swing-arm and install the 85 swing-arm.
Put it in and discovered that it was 4 mm too narrow at the pivot end.
Checked and discovered that there are 2 washers/spacers that sit under the dust caps.
I didn't have these spacers. I could order some & wait.
Just for fun, I installed the rear wheel, and found that it was about 4 mm too narrow for the swing-arm
Checked and found that the 86+ bikes use a different rear wheel spacer and a different caliper bracket, than the 83.
Maybe the spacer & bracket are a different thickness that the 83 bikes. I don't know.
Anyway, after finding this, I decided to just use the 83 swing-arm.
On to the front end. Installed the calipers and master cylinder.
Went to the parts collection and found some braided steel brake lines.
They didn't fit.
The banjo ends were perfectly straight and the fittings on the lines hit the lower tree.
Decided to just use the stock brake lines.
They didn't fit.
I'm using a set of 85 forks, but I'm not using the oem clip-ons.
Instead I'm running a set of regular 7/8" bars, and they sit higher than the clip-ons.
So, the brake line form the master cylinder to the splitter, was too short.
I went home.
Today, I picked up a new brake line from the wreckers.
Brake lines are all installed. Bars, controls, and new grips are on.
Rear fenders and wiring harness are also in place.
Interesting story on the wiring harness.
My buddy rjreg called me about a year ago and asked if i wanted it. For free.
I said sure, and he mailed it down to me.
I really wanted some braided steel lines on this bike, and was bummed when mine didn't fit.
While I was at the bike shop this morning, I checked on a set of Goodridge brake lines.
Even with my 'good guy, friends and family' discount, it would still cost $150.00.
F*ck that. This is a Low Budget Project.
For the most part, I'm trying to build it out of spare parts that I have lying around.
Moderator
Moderator
#1123 Post by silverstrom » Fri Dec 11, 2015 1:59 am
Off Road wrote:[
No, I don't. That belongs to someone else now, but I do have all of the swingarm, wheel, and caliper parts you're missing. At the 'good guy, friends and family' discount, of course :smt003 Just sitting on my new yellow bike lift gathering dust now.
Off Road
#1124 Post by Off Road » Sat Dec 12, 2015 3:14 am
Changed the brake fluid, and bled the brakes.
Installed new brake pads in the rear. Ordered new pads for the front.
Mounted the gauges, turn signals, headlight bucket, and foot-peg brackets.
Got the wiring harness all in place and most of the electrical components are connected.
And I got the engine bolted into place.
Next task is to modify the wiring so that the 85 CDI & Stator, will plug into the 83 wiring harness.
hondaror
#1125 Post by hondaror » Sat Dec 12, 2015 9:47 pm
Other than this, are you working much Steve?
