On April 26, I posted a pic of the bike.
Haven't even looked at the bike for the last 3 weeks because I've been busy / lazy / unmotivated.
Tonight I was looking at the bike, and casually took off 1 part, then 1 more, then another, and before I knew it I was reaching for tools.
Didn't get very much accomplished, but every little bit helps.
But, I'm getting ahead of my self. Let's back up for a moment.
I'd like to thank RuZty, for his post.
Very perceptive. You are correct. I did
Not pressure test my engine.
And you're post was great. A very polite, well written, humorous way of telling me to, "stop being a dumb-ass".
Well done.
As RuZty pointed out, a number of well respected, experienced, knowledgeable, engine builders, told me to pressure test the motor..
And despite all their good advice, I decided not to do it.
After hearing this confession, you're probably thinking 3 things.
1 - He's an idiot
2 - Why? Why would he not pressure test?
3 - He's an idiot.
Well, here's my feeble explanation.
1 - I didn't have $300 to buy a Motion Pro pressure test kit.
2 - I didn't have time, or the desire to run all over town sourcing parts, and then assembling a pressure tester.
3 - I don't think I have an air leak.
Before the bike seized last Summer, it ran perfect.
OK, probably not perfect, but it ran pretty good.
- Started on 3 or 4 kicks,
- Had a smooth steady idle, (hot or cold)
- Pulled away from a stop without any hesitation,
- Had a bit of a 5K stumble, but pulled hard from 6K to 9500 rpm.
And then, all of a sudden, for some unknown reason, after running great for 600 miles, the Right cylinder overheated, detonated, overheated, and seized.
A few years ago, I had a base gasket leak one of my other bikes, and it was immediately obvious.
I've been taking to a couple of fairly knowledgeable guys, and I've read a bunk of posts, and I'm cheap, and I'm lazy,
and I've manged to convince myself that my engine cases didn't leak.
So, I slapped the motor back in the bike, fired it up, and put 130 miles on it.
It runs perfect.
OK, probably not perfect, but it runs pretty good.
- Starts on the 2nd,
- Has a smooth steady idle, (hot or cold)
- Pulls away from a stop without any hesitation,
- Has a bit of a 5K stumble, but pulls hard from 6K to 8000 rpm.
Hmmm. That sounds familiar.
The only problem/concern that I see, is that the Right spark plug looks "different" than the Left plug. WTF's up with that?
(Could just be I'm just being paranoid, but I don't like it)
When I "rebuilt" this motor last Winter, all I really did was bore a couple of cylinders, and install a bigger set of pistons, along with some new oem gaskets.
After 130 miles of riding, I assume the rings have seated, and the engine's broke in.
So, 3 weeks ago, I pulled the tank off, and checked the compression.
122 psi - Left Cylinder
124 psi - Right Cylinder.
Hmmm. A little bit down from what I was expecting.
I was getting 130 psi, using this o-ring head with my old 31K cylinders.
Maybe it'll still come up some.
And that brings me to tonight.
Engine has reasonable compression.
It starts good, it idles good, it accelerates good, it pulls hard from 5500 to 8000.
It runs fine, I don't see any indication that it has an air leak.
So here I sit, Convinced that I don't have an air leak.
Paranoid that I do still have an engine problem.
And Glad that I know the right people, and have enough spare parts, so that I can rebuild the motor again for only $140 and a case of beer.
However, if it doesn't have an air leak, then why does it keep seizing the Right cylinder.
And did any of the small changes that I just made to the bike last Winter, fix whatever problem I had.
And if I didn't fix the problem, when is it going to seize again. 600, 700, 800 miles?
And what's changing, so that all of sudden, without warning, this engine goes from running good, to catastrophic failure?
And how do I know if it's going to happen again?
And why do the plugs look so different?
And Ya, I'm wee bit paranoid.
Fortunately, I have a plan.
It may not be the smartest plan that I've come up with, but it definitely won't be my worst plan.
At the very least, it should be fun and entertaining.
Box of new parts arrived yesterday
Won't be able to work on the bike until tomorrow. I'll wait until then to open it up.
But I am kinda excited to see what it looks like
