Riddle me this - headlight dims signals glow when revved.
nokturnal
#1 Post by nokturnal » Sun Aug 12, 2018 10:50 pm
I have just got my bike together, converting it from a track bike (all "legal" wires were just cut, headlight, signals, etc.
). I am pretty sure I wired everything up correctly. Multimeter and wiring diagram in hand...
Everything seems to work as it should when the bike is just on the battery. When I rev the bike up when running though the headlight dims and the signals start to glow.
The same thing happens with a battery from another bike, and my brand new lithium. 3 regulators (maybe all bad??).
Ideas? I need this thing ready to go by Thursday...
:smt017
hondaror
Re: Riddle me this - headlight dims signals glow when revve
#2 Post by hondaror » Mon Aug 13, 2018 3:33 am
Could be a ground issue on the bike. Also, stator could be on the way out.
addicted to relics
#3 Post by addicted to relics » Mon Aug 13, 2018 1:11 pm
All power must past the regulator you have a wonky regulator buy one used or new from Japan not anything from china
Ebayru
#4 Post by Ebayru » Mon Aug 13, 2018 7:35 pm
My lights would dim on revving when my regulator was faulty. A replacement cured the problem.
1990 RZ350 (Canadian)
1974 Suzuki GT550 with sidecar
1978 Yamaha DT250
nokturnal
#5 Post by nokturnal » Mon Aug 13, 2018 11:26 pm
looks like it is a bad ground on the headlight. Will confirm tomorrow.
:smt017
OldTZracer
#6 Post by OldTZracer » Tue Aug 14, 2018 11:29 pm
Its backfeeding somewhere, so I second the bad ground - but check you haven't got a dark brown (signal) plugged into a light brown (switched power). Also, unplug the flasher relay & see what happens...
nokturnal
#7 Post by nokturnal » Wed Aug 15, 2018 11:12 am
yeah. tried all that. it was defo the headlight.
:smt017
addicted to relics
#8 Post by addicted to relics » Mon Aug 20, 2018 5:53 pm
good to know ground is easier than a reg/rec problem
nokturnal
#9 Post by nokturnal » Tue Aug 21, 2018 5:33 pm
now its just the dash lights... signals and high beam.
The signals themselves and headlight has had separate grounds run
:smt017
