Daily Supermoto
Re: Stunt Bike
Like the street fighters shirt,luv this bike even more!Man it would be some fun....
Re: Stunt Bike
Got the mirrors anodized black, and the adapters powder coated black. The stalks were previousy powder coated. Finally finished, and back on the bike.
Re: Stunt Bike
Just some details.
The tailight spacers I made needed to be black. Also found another OEM bracket that had ugly zinc plating.
Re: Stunt Bike
hey smoker just seen your wr250x post ,I ride mine as a daily rider also,like you I cant leave it stock don't know if you found grafics but wheeling cycle supply has the red ones,might be what your looking for? I will post some pics once the FZ8 is back together and out of the livingroom again cant leave it stock I think I have a sickness.
Re: Stunt Bike
Yeah, this was going to be my first custom bike with graphics.rd guy wrote:hey smoker just seen your wr250x post ,I ride mine as a daily rider also,like you I cant leave it stock don't know if you found grafics but wheeling cycle supply has the red ones,might be what your looking for? I will post some pics once the FZ8 is back together and out of the livingroom again cant leave it stock I think I have a sickness.
But, I changed my mind. Just gonna lay down some black vinyl for contrast using my own pattern ideas.
I've got the sickness, too. But, it's a sickness I can live with.
Re: Stunt Bike
Just hit 10,000 miles on the ODO.
I love this bike!
I love this bike!
Re: Stunt Bike
Superb! hows those graphics coming along?
Re: Stunt Bike
Is there a reason you went with a low slung pipe? I would suspect that will be very easy to damage in the event of a fall.
We went with an FMF which is high mounted like this and it seems to tolerate smaller drops with no damage. Am also running a pipe crash protector which helps.
Looking at the two pics I just noticed your pipe runs under the lower frame cradle which greatly reduces ground clearance. I'd have destroyed that pipe in a ride or two because of that.
'85 FZ750
'85 FZ750
Re: Stunt Bike
Sweet new rubber.
Got the chain and rear end all cleaned and lubed too.
Re: Stunt Bike
Installed a serious headlight bulb. Huge difference in brightness!
Will have to see how hot the housing gets, and will use the battery tender regularly.
Blaster vs OEM.
Blaster vs OEM.
Re: Stunt Bike
For a long time, I've felt a slight click when I turn the bars.
Didn't see anything else, so I pulled it apart to check the head bearings and races.
Bearings and races look okay, but I'd still like to change them as long as it's all apart.
Bad news - my bearing puller doesn't fit between the fork stops.
More bad news - my bearing race tool wouldn't catch the lip of the upper race - so, I could only change the upper bearing.
I'll repack and adjust everything. Hopefully, the click will be gone after all this!
Re: Stunt Bike
Decided to revamp the rear as well.
Pulled the rear shock to clean it and adjust the preload, compression & rebound (space is limited on the bike).
The first test ride was scary as shit. The handling was completely fucked up. Kept adjusting everything - now it handles great - way better than before.
And that damn click in the head tube is GONE!!!
Re: Stunt Bike
Took my wheels & tires to Pro Italia for mounting and balancing.
Their top mechanic took a break from the factory Tuono to work on my WR250 wheels.
Love it when someone knows how to do things right. Both tires are spot on!
Last time someone else did my tires - the front tube ended up in the back tire and the rear tube in the front!
Re: Stunt Bike
Found black Scotch Super 88 tape in 1.5 inch width to cover the white reflective VIN sticker.
Re: Stunt Bike
The white Samco hoses started turning yellow after a couple of months.
Couldn't take it any longer!
Before:
After:
The areas that were covered with hose clamps are still white. Won't be buying white hoses again.
Put on atraumatic hose clamps so the new hoses don't get chewed.
Before:
After:
