Larger diameter axle in RZ forks
DRC
#1 Post by DRC » Sun Jun 17, 2018 12:41 am
I race a CB350 (Sorry about that) and the forks are tweaked.
I have a good set of RZ350 forks and triples that will fit the CB steering head with some bearing and spacing changes and I can get a couple of spacers made to fit the CB wheel between the fork legs (cast rims are not allowed as they are not period correct)
The problem is that the CB wheel has a 15mm axle. I’m wondering if there is enough meat on the Rz forks to have them bored to accept a 15mm axle or should I just use the 12mm with new bearings? I would imagine the 15mm axle would be an improvement
Thanks in Advance
Re: Larger diameter axle in RZ forks
#2 Post by hondaror » Sun Jun 17, 2018 4:15 am
I would look into getting the right bearings first. Then no modifications or butchery is needed.
Yellow and Black RZ
#3 Post by Yellow and Black RZ » Wed Feb 13, 2019 6:47 pm
Yes there is plenty of room to open up the axle holes. Radius would be only 1mm which for us Americans is only .040"
'85 RRZ350 - Hacked.
OldTZracer
#4 Post by OldTZracer » Thu Feb 14, 2019 2:47 am
Just a question - do the tripleclamps have a similar amount of offset? Are you going to end up with a different amount of trail that changes the handling?
evan_calgary
#5 Post by evan_calgary » Fri Feb 22, 2019 1:25 pm
Bore em out just make sure straight. Should be plenty of material. Larger axle should be improvement. The RZ one is microscopic for an axle.
nokturnal
#6 Post by nokturnal » Mon Feb 25, 2019 1:13 pm
:smt030 just watch you don't bend the forks with the new super stiff axle...
i would base it on how new the bearings are, myself... will the axle really make that much difference on those forks?
:smt017
evan_calgary
#7 Post by evan_calgary » Wed Feb 27, 2019 11:54 pm
nokturnal makes a decent point. It is likely marginal improvement with a large axle but i've not done a back to back test. Given the comparable diameter of the tubes to the axle I would not be concerned about bending the forks.
Given the low cost of a proper replacement set of forks of around a hundred bucks your probably best to just find some replacements?
nokturnal
#8 Post by nokturnal » Thu Feb 28, 2019 9:49 am
evan_calgary wrote: Wed Feb 27, 2019 11:54 pm nokturnal makes a decent point. It is likely marginal improvement with a large axle but i've not done a back to back test. Given the comparable diameter of the tubes to the axle I would not be concerned about bending the forks.
was joking about the forks evan.. :smt033
:smt017
evan_calgary
#9 Post by evan_calgary » Thu Feb 28, 2019 1:30 pm
My bad!
