1975 RD 350 brake upgrade
75RD350rider
#1 Post by 75RD350rider » Wed Nov 29, 2017 7:58 pm
I am spoiled by the 2 finger stopping abilities of the Phoenix Project and the RZ 350 and I had the R1 adapter bracket laying in the Girly Bike parts pile since the Gap when the Haase gave it to me.
So about a week ago I started gathering the required pieces from good ol Flea Bay...
ImageR1 front brake setup complete with Goodrich braided lines and new race pads $99 shipped. The conversion also required an FZR 600 rotor, a 12MM spacer ( made by cutting what the Haase referred to as a hat, from the center of a factory disc) and 6 M8 x 40 MM bolts, and some M8 and M10 washers for spacing.
.Image
Tim Steele in Front Royal, VA
75RD350rider
Re: 1975 RD 350 brake upgrade
#2 Post by 75RD350rider » Wed Nov 29, 2017 8:00 pm
I had some issues (self induced) with the spacer made from the hat. I had to take it all back apart. and it took some time facing the spacer and now the rotor has no discernable runout. On to spacing....
75RD350rider
#3 Post by 75RD350rider » Wed Nov 29, 2017 8:01 pm
This morning I worked out the spacing issues and assembled the rest of the system. I also had to grind a little off the caliper for spoke clearence. The R1 system operates the two lines with a double banjo bolt so I looked through my parts and found a decent single banjo and luckily the goodrich braided line is the perfect length. I hooked up my mityvac and bled the brake. Then I made a small subharness to plug into the factory pressure switch wiring so the brake light would work. Then I took a vigorous test ride and am pleased to report that despite the piston orientaion being incorrect big vs small leading that I can haul it down from 90 MPH with two fingers. The feel is good and the braking is linear and progressive. The only drawback is the RH forward fender brace will not work so I am on the hunt for a RD 400 or XS 400 front fender. Big thanks go out to M in SC for the bracket adapter and the help figuring out the spacing...
The rotor was $29 shipped for two and the bolts were $17 shipped. The whole mod is easily reversible as everything is bolt on and the original wiring for the no longer used pressure switch is untouched.
two-stroke-brit
#4 Post by two-stroke-brit » Fri Dec 01, 2017 3:05 pm
Thats a huge rotor .
nice upgrade for sure.
thinking about replacing my calipers on the LC but must do the fork swap first.
then the new pipes so its a ways down the list.
marks a helpful guy for sure.
1982 YAMA RD350LC
2004 BMW R1150RT
1989 FZR1000
1994 FZR1000
75RD350rider
#5 Post by 75RD350rider » Fri Dec 01, 2017 6:27 pm
Yes he is... It really stops good now... Here is a better picture:Image
75RD350rider
#6 Post by 75RD350rider » Wed Dec 20, 2017 11:38 pm
After further consultation with M in SC and some back to back rides on the RD and RZ I ordered and received a 12MM master cylinder in an effort to get a little more feel. $20 shipped from an ebay vendor named fancy scooters and it even has an electrical brake lite switch just like the 14 MM R1 master cylinder currently installed so it should be plug and play. I hope to get it installed and bled tomorrow morning after I feed my Baby Mommas before work and hopefully a short test ride.
75RD350rider
#7 Post by 75RD350rider » Thu Dec 21, 2017 5:58 pm
On and bled in 15 minutes. About 3 pumps after this picture it burped the rest of the air out. The feel is perfect and now we have 1 finger braking for normal stops and 2 if you have to stop quick. Thanks again M in SC.
75RD350rider
#8 Post by 75RD350rider » Thu Dec 21, 2017 6:09 pm
Done and Done!
two-stroke-brit
#9 Post by two-stroke-brit » Thu Dec 21, 2017 8:09 pm
nice upgrade again :smt006 .
more finessing than upgrade but anything that improves the ride is a good thing.
1982 YAMA RD350LC
2004 BMW R1150RT
1989 FZR1000
1994 FZR1000
JonW
#10 Post by JonW » Thu Dec 21, 2017 8:54 pm
I would be a little weary of that cheapo chinese master cylinder, but Im thinking youre not really throwing this bike at the scenery in the same way you might faster machines?
My Projects:
see them all at www.2smoked.com
82 RD 421 LC Hybrid
82 RD 250 '51L' YPVS LC
83 RZ350 LC2 Resto
Like Watches? Try www.PloProf.com and www.DeskDivers.com
75RD350rider
#11 Post by 75RD350rider » Thu Dec 21, 2017 10:03 pm
So far so good. If I run across a Brembo or Nissin in that size I will snag it.
75RD350rider
#12 Post by 75RD350rider » Mon Feb 12, 2018 2:48 am
After the brake upgrade I had to run with 3 of the 4 braces on the fender as the RH forward brace would no longer fit because of the caliper. I got this 2017 Yamaha SR400 fender for cheap off eBay. It took a bit of dremeling to elongate the holes and had to squeeze the mounts in some to get it to fit...
two-stroke-brit
#13 Post by two-stroke-brit » Tue Feb 13, 2018 2:56 pm
looks good :smt023
1982 YAMA RD350LC
2004 BMW R1150RT
1989 FZR1000
1994 FZR1000
75RD350rider
#14 Post by 75RD350rider » Wed Feb 14, 2018 6:31 pm
Thanks!
