It is currently Sat Aug 18, 2018 11:42 pm
Post new topic Reply to topic  [ 4 posts ]
 Post subject: Shock bushing
PostPosted: Tue Oct 17, 2017 2:25 am
What is the size of the bushing to get at mc master-Carr for the R6 rear shock on the rz
 Post subject: Re: Shock bushing
PostPosted: Tue Oct 17, 2017 9:20 am
You need two 6659K36 Metric SAE 841 Bronze Flanged-Sleeve Bearing for 18 mm Shaft Diameter, 22 mm OD, 18 mm Length
You need two 6659K41 Metric SAE 841 Bronze Flanged-Sleeve Bearing for 20 mm Shaft Diameter, 24 mm OD, 16 mm Length
PostPosted: Tue Oct 17, 2017 1:27 pm
thanks
Users browsing this forum: Evans Ward and 2 guests
