RD350LC 4LO Build
Moderators: rztom, 2smoke
tacky1
Re: RD350LC 4LO Build
#61 Post by tacky1 » Wed Nov 07, 2018 10:26 pm
Anyone have any idea what this block is for, I picked up a Japanese harness so I could use a proper light switch, Everything plugs in except for this mystery block, Its under the tank by the coil, Its in with the switch gear blocks, I'm stumped....
nokturnal
#62 Post by nokturnal » Thu Nov 08, 2018 10:35 am
the colors make me think kickstand switch.
the other thing I wonder about is their over-the-limit speed indicator light that is at the bottom of the jap gauge cluster.
:smt017
nokturnal
#63 Post by nokturnal » Thu Nov 08, 2018 10:36 am
:smt017
Zedixe13
#64 Post by Zedixe13 » Thu Nov 08, 2018 11:07 pm
Electric diagram for the Canadian LC
Full size here
https://flic.kr/s/aHskpe6WUD" onclick="window.open(this.href);return false;
tacky1
#65 Post by tacky1 » Thu Nov 08, 2018 11:45 pm
Thanks Guys, Its a block for a headlight relay used on Japanese spec bikes, Have the relay ordered...
tacky1
#66 Post by tacky1 » Wed Nov 21, 2018 10:59 am
Picked up the relays, Fitted them and fiddled with the wires for a few hours and got everything working, Got the clocks on, brakes on and bled, chain and sprockets on, Mudguard and plate holder etc, Head is back from Bill Wilson, Looks class, Nice job Bill, Nice to see you testing out the new mill on the head :)
Porting is roughed in, Have to finish that up, Few more MM here and there need to be removed :P
Bunch of other niggly bits, Progress.. Havent sent the bodywork out yet, Painter is completely backed up, Prima donnas if you ask me.. :P
2smoke
Moderator
#67 Post by 2smoke » Wed Nov 21, 2018 1:27 pm
That rear shock looks like a nice stout piece.
You are doing a first class job. :smt023
I am amazed how much work you can do in a short time. Whats your secret?
:smt038
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
nokturnal
#68 Post by nokturnal » Fri Nov 23, 2018 2:58 pm
whered you get those caliper brackets? I would like some...
:smt017
Hooligan
#69 Post by Hooligan » Fri Nov 23, 2018 4:00 pm
Those are NK Racing caliper brackets from the UK. They are good for mounting Blue Spots .... or in this case Gold Spots. I've got a set on my LC.
'85 FZ750
tacky1
#70 Post by tacky1 » Fri Nov 23, 2018 9:08 pm
Yep, Nigel over at NK racing will sell you a set..
tacky1
#71 Post by tacky1 » Sat Nov 24, 2018 6:55 pm
Heads and barrels sanded, masked and painted
Bare
#72 Post by Bare » Sun Nov 25, 2018 12:26 am
Nice work! best use Good rings though, those are Large unsupported holes .. Either OEM Yamas or Wisecos.
tacky1
#73 Post by tacky1 » Mon Nov 26, 2018 1:01 am
Is this shit for real or is this a joke!!!
https://www.ebay.com/itm/YAMAHA-4L0-814 ... Swtbxbz~G5
nokturnal
#74 Post by nokturnal » Mon Nov 26, 2018 10:24 am
wow... i just sold a complete running engine and electrics for less.
:smt017
tacky1
#75 Post by tacky1 » Sun Dec 09, 2018 2:14 pm
More Progress, Heads and barrels on, Reeds in, Clutch cover fitted, Pressure tested, Lost .25 PSI in an hour, I'm happy... Bunch of other little bits and pieces, 2Stroke oil in and pump bled, Radiator and cover fitted and full of coolant, Gearbox oil in, We nearly have a runner. :)
