Hi guys, need a little help with my 81 250LC , can someone tell me the lenght of the spacer that fits between the bearing and front sprocket as I am sure the one I have is to long ,maybe RZ one? As the sprocket sits proud of the spline so the recess in the nut won't go over the spline which also means the lock washer isn't on the spline either.
The bike came as a "kit set" so maybe wrong spacer was put in the bits is what I'm thinking.
Front sprocket spacer
Re: Front sprocket spacer
I can't give you the exact measurement at the moment, but the rz ypvs one is wider for sure.
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
My engine is on the bench. It's 14mm.
1982 RD350J aka RD350LC Canadian
1971 Kawasaki F5a Big Horn
2013 NC700X
Judge people by what they do and not what they say they will do.
2013 NC700X
Ok cool that makes sense, I will drop mine off to machine shop to be shortened.
Thanks for that
Thanks for that
