head skimming and reprofiling
Moderators: rztom, 2smoke
AZRD350LCGUY
#1 Post by AZRD350LCGUY » Thu Nov 10, 2016 3:29 pm
I would like to get my head skimmed and reprofiled.
The question is where to do it.
Any answers??
1971 Kawasaki F5a Big Horn
2013 NC700X
Bare
Re: head skimming and reprofiling
#2 Post by Bare » Thu Nov 10, 2016 4:19 pm
Told you before:
http://home.earthlink.net/~scloughn/" onclick="window.open(this.href);return false;
Unlikely to find better. Not too far away for shippings to be a deal breaker
whyzee79
#3 Post by whyzee79 » Thu Nov 10, 2016 6:02 pm
Eric Gorr Racing also does a nice job on two stroke machines. He is located in the upper Midwest.
2smoke
Moderator
#4 Post by 2smoke » Fri Nov 11, 2016 10:08 pm
GPL Racing Nova Scotia
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
wolfman
#5 Post by wolfman » Fri Nov 11, 2016 11:39 pm
Gotta be something in south eastern AZ ?
Plenty two stroke machine shops around that can help you out.
Search your map and see, you might be surprised to find out what's in your town.
Found a banshee shop that's tits, ... 5 minutes from my house.
Tarozzi fork brace
vmxwinn
#6 Post by vmxwinn » Sat Nov 12, 2016 12:54 am
Brian Turfery
gordo555
#7 Post by gordo555 » Thu Dec 08, 2016 1:04 pm
Scott Clough Racing! Scott did my barrels with stage 1 porting, fitted pistons, and re machined my head with domes set for compression, squish (perfect at 1mm upon assembly), my high local altitude, and fuel octane level. He also machined for an o-ring, so no more troublesome head gaskets! He does custom design profiles for every head based on the parameters you give him, and what your performance goals are. He's not far from you in the California desert.
I can't recommend him highly enough, This guy is the ultimate pro. (he also does land speed record motors). Here's the work he did for me..
two-stroke-brit
#8 Post by two-stroke-brit » Thu Dec 08, 2016 2:56 pm
The crank looks to be missing something.
cant put my finger on it but just dont look right. :smt044
gordo555
#9 Post by gordo555 » Thu Dec 08, 2016 6:00 pm
two-stroke-brit wrote:The crank looks to be missing something.
Since I was sending him the LC top end, I also sent him the cranky bits to press up and true for an Aermacchi 2stroke I'm building (Harley Davidson SX-125). He's a multi-talented guy, and I'm NEVER working on just one bike.
two-stroke-brit
#10 Post by two-stroke-brit » Thu Dec 08, 2016 10:01 pm
Thats cool.working on more than 1 gives you options while waiting no parts. :smt038 :smt023
gordo555
#11 Post by gordo555 » Thu Dec 08, 2016 11:57 pm
Yeah, except when you forget where you were, and where you put that box of parts you had to move somewhere so you'd have room to get that swingarm up on the bench, and trying to remember whether the spring washer went over the flat shim or under it...
Questo vecchio rz
#12 Post by Questo vecchio rz » Sun Dec 11, 2016 3:42 pm
In addition to Scott Clough. http://home.earthlink.net/~scloughn/" onclick="window.open(this.href);return false; , who really is " The Guy" He does reprofiling for many people" there is also Harry Klemm in AZ, Lake Havasu. http://www.klemmvintage.com/" onclick="window.open(this.href);return false;
He's qualifued to do anything, and is also a experienced vintage builder and racer. If you know classic DG performance parts...you know Klemm. Either of these gentleman can build you classic or modern takes on your 2 stroke projects. There master's at what they do and are still at the cutting edge of development for our old bikes.
Between the two of them you have 80 years of 2 stroke racing knowledge! Think about that for a minute :smt002
