bobbyd
#1 Post by bobbyd » Sat Sep 29, 2012 8:53 pm
Zedixe13
#2 Post by Zedixe13 » Sat Sep 29, 2012 11:08 pm
For your inspiration , I just completed my rear RZ wheel setup on my LC .
steveloomis
#3 Post by steveloomis » Sat Sep 29, 2012 11:34 pm
You got my attention. I looked at doing this. I am just wondering about the details. Any pics?
Zedixe13
#4 Post by Zedixe13 » Mon Oct 01, 2012 2:34 am
I don't want to hijack Bobbyd's tread but basically it's the same setup as on the RZ : Rear wheel , complete braking system ( different master in my case ) . I cut the small RZ caliper's bracket '' channel '' from an old RZ swinger and welded it at the same place on the LC . Same for the oil line retainer . The home made bracket for the master is similar to the one we see on sale on some UK sites . Brake pedal is LC with welded RZ brackets for return spring and fitting for the master actuator . 5 mm spacers under the foot extension for space for the spring and actuator . Rear swing was spread about 5mm on one side , bent inside on the other to center the wheel with the front sprocket and the front wheel . Reservoir is from a RZ500 and is kept in place with a bracket bolted to the nearest bolt inside the innner mud guard . Mucho fitting to get the best configuration but it's done and I'm very happy with the result .
bobbyd
#5 Post by bobbyd » Mon Oct 01, 2012 5:22 am
Re: Alex's 350LC
#6 Post by JonW » Sun Apr 14, 2013 4:23 am
Alex came over today and I got to see this bike, its looks and sounds great in the metal. I should have pulled the LC421 out and photo'd them together as they seem like they may be the same shade of yellow. nice bike m8!
bobbyd
#7 Post by bobbyd » Sun Apr 14, 2013 10:14 am
Re: Alex's 350LC
#8 Post by JonW » Sun Apr 14, 2013 6:28 pm
Evolution is always good. I am still changing things on my bikes as newer or better parts and ideas come along as we spoke about yest. Cant want for the full rebuild, will be fun.
Torpedo7 was the place we were speaking about :)
