My rz350 race bike
My rz350 race bike
Hey, been watching the forum for a little while now. I just recently purchased this rz, as well as a bunch of other parts to build another one!
its got a stock motor, fox rear shock, fork emulator and progressive springs in the front. steering damper, One off fork brace, R1 front brakes, and stock canadian pipes.
I will start another thread for the street bike im building. its gonna have:
fzr600 swingarm
cbr f4i shock
ported cylinders
28mm pwk
stock reed cages w/ bansee reeds or similar.
inverted fork front end (still unsure of what im gonna use)
frame braced
ect ect...
fzr600 swingarm
cbr f4i shock
ported cylinders
28mm pwk
frame braced
ect ect...
85' rz350 - R6 rear shock, progessive springs & race tech emulator, Fork brace, steering damper, 01' r1 front brakes, GPL Racing ported cylinders & milled head, GPL Racing gp exhaust, V-force reeds, reed spacers, 28mm PWK'S, Zeeltronic pcdi -10v
Glynn, I am going to race it, starting next year. As far as classes, I think its 2 or 3 i can race in; vintage class, the sportsman class ( i think) and a class called formula 46, where the age of the rider plus the age of the bike must be over 46. Although many riders in this class are older or close to 46 and running modern sportbikes. This is the ARL website for more info: http://www.atlanticroadracing.com/
check out the forum for rules and registration info. glynn are you thinking about racing next year? it would be nice to see another rz out there!
L.B the rotors have holes drilled to match the rz wheel and the calipers have been spaced out by a custom bracket.
- This old RZ
NICE BIKE Sounds like fun. Assuming your not a racer,but new to roadracing,If your experienced and know what direction your going,no need to read much further. But if this is new to you ,some suggestions ,that I think will benifit you
Keep your FOX shock!!,get it rebuilt,the CBR shock will be TOTALLY USELESS for racing,the Fox shock is FAR better. It should be Adj,and ride highth Adj and valved,sprung correctly..the honda shock conversion is sutibale for street only at best..its all wrong
The bike you have is a fairly capable machine as she sits,and will more than likley be FAR slower around a racetrack if you just throw a used shock/front end conversion at it.
Dont skimp on your shocks/brakes..before any engine,chassis work etc.. SORT YOUR SUSPENSION use a quality"racing " shock. You could do a front end conversion..but again probably not required a good set up front end ridden well,is just as fast for 90% of racers,if you must do a conversion I'd look at used TZ front ends..complete w wheel. Your suspension is JOB NO.1. get your suspension conversion set up/revalved etc..Dont just use what you bolt on ,youll be sorry.
You dont really need any chassis reinforcing..but it wont hurt if you want to.
Swingarm FZ600,Its tried and true,but I'd recommend a metachex or JMC if you can locate one. Id still try to locate a complete 88-89 TZ rear and front complete with wheels! Buy a roller and utilize the parts.there getting very hard to find now and prices are going up. As MODERN TIRES WILL BE YOUR LARGEST ADVANTAGE.
Although your pipes are as heavy as boat anchors,they perform quite decent and ...they crash well there solid. So you might not want to blow too much on your exhaust pipes,but again you will lose close to 15 lbs by changing them,thats pretty serious thing to consider,free power,costs nothing other than a set of cheap used chambers.
As for the porting,and carbs..no problem there,you have a guy close to you that can set you up on that front. Not too sure of the PWKs, but I've heard good things when dialed in. Being a race bike, Youll have to check and re-jet for each race day/track anyways.
Have fun and post updates,
BTW,what you have is pretty capable as is,you might want to run her as is for awile to see how it performs give yourself a good solid platform for a baseline.
RZ thanks for the info, but all those modifications are for the street bike im building. Next season will be my first racing season so im pretty new lol. As for the race bike, im keeping it as is for a while. my suspension is pretty spot on for me, and the motor i wanna keep stock untill i finish throwing all my money into my street bike build lol!
That's a great bike, and I like the stockness of it all. It's got all the right stuff, just enough to make it a hoot to ride and not be to expensive to maintain. It probably has a super smooth power band with that stock pipe! It looks like it has a oversized radiator from the picture, is it? Just awesome.
Today I finished up winterizing my bikes, figured I'd take some pics of them too.
my 03 ZX6R 636
My race bike naked, I installed some clipons and had to make some brackets for the upper fairing. The 636 in the back with my girl's Ninja 250 in behind
here are some pics from the brackets I made. Their nothin special, or pretty lol! But their functional, I save weight, and they were free.
I just gotta weld on a couple washers on the back of the bottom bracket to space it out a little. Then paint.
my 03 ZX6R 636
haha ya it looks a lot better with some paint. like is said the brackets aren't gonna win any beauty contest lol. Im gonna throw another coat of paint on tonight, ill post some pics of the finished product after.
