Iron's RZ Upgrades.
Iron's RZ Upgrades.
I have been working on the RZ for a while now. Some of the upgrades include a Zeel PCDI-10V, R6 cooling fan, new fuse box, new dark windscreen, P-Coated Pipes. Still want and or need the Fork Brace and the Stabilizer when I get to it. Hope you like it.
If someone could post a close up of their steering stabilizer that would be great.
Iron on the Bayou.
84 RZ-350
Bore 64.5MM, Wiseco. Ported by Wicked (Recreational). Wicked's Billet Head, Zeel Iggy, V-Force 3 Reeds, Y-Boot K&N Filter, Stock Carbs. Spec 2 Pipes (F-1's). R6 Cooling Fan.
84 RZ-350
- aaronmvrider
Looks very good indeed and clean enough to eat your dinner off! Well done!
- Evans Ward
A stunner!! And yes, he does ride and beat on that thing as I can vouch riding with him over the past few years. Ya'll would be proud of how we ride our RZs as intended and designed!!
Another show winner for certain. You do excellent work.
Do you have any detail on mounting up the fan?
Did you make brackets or poke thru the fins of the rad?
Photos of the fan mounting???
Thanks.
Thanks.
Ken's Garage
No I don't but I think It was wicked who first posted the upgrade. You may be able to seardh the post.
To fasten the fan you need to purchase a kit from auto parts store. It is a kit to fasten a transmission cooler. Basically zip ties with a couple of rubber pads.
Very easy project.
Thanks everyone for the nice replys.
Very easy project.
Iron on the Bayou.
84 RZ-350
84 RZ-350
- aaronmvrider
?? from memory the damper was from economy cycles and mount brackets were from rdlc crazy.... perhaps economy cycles also have these mouints....iron wrote: Where did you locate these parts and how much $$$$$$? Thanks
pretty reasonably priced.... under $300 ???
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
