Just finished my 31KR enlarged
here the end of work on my enlarged 31K frame
Fzr1000 swinger and fork and marchesini big wheels
looks bigger and stronger than stock 31k one
now weather and temperature are rigid here to test it in
a good condition, but after first run i find good handling
http://www.2t-special.it/foto/trilogia/index.html
here ypu can find a little gallery of my yellow trilogy
Alex
nice bike
I all ways liked the yellow and black colors
on the aniversary model two years ago Yamaha came out with that color scheme on the R6 and R1
Good job
Good job
1964 Austin Cooper S 1071cc
1999 Ducati ST 4
1999 Ducati ST 4
- aaronmvrider
Whippersnapper, Yes Arrow made a chambers specific for RZ
several years ago, now i'm not sure that are still available
Aaron, kick starter is a mix of RZ350 and RZ 500 parts
pieces clamped on shaft is original 350 one
lever is 500 (only lever, you must take off clamp and security washer)
now ypu can put 500 lever on 350 clamp, but clamp is too short
i drilled and tapped it and screw in a new washer vhit collar to
firm lever.
i hope to explain correctly the modify
firm lever.
Alex
- aaronmvrider
cheers looks like i will be hunting down a 500 kickstarter in the near future
i have just had my tank repaired it was leaking and i should get another 25 years out of it
i received my rz 500 parts also and am very close to fiinishing it off almost at kicking it over stage will be music to my ears i have a stainless set of lomas on 350 and a mild steel set on 500 that i have had ceramic coated cant wait
Aaron
Aaron
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
