RD350Lc2 YPVS
Good with a camera? Post pics of your favorite 2-stroke here!
Jimmye
RD350Lc2 YPVS
#1 Post by Jimmye » Sat Oct 19, 2013 2:50 pm
My restored RD350lc2 YPVS.
Setup:
Pistons: 65mm Wössner
Ignition: Zeeltronic PCDI-10v
Carburetors: Oem Mikuni 26mm
Locked power valves.
To come:
Mick Abbey expansion chambers with carboon cans
Boost bottle
Drilled airbox
New Power valves
keihin pwk 28mm
A nice paintjob
http://www.youtube.com/watch?v=oRJpHSfV35M
Future setup on my RD 350 1984 RD350LC2 YPVS:
Mick abbey steel pipes with carbon fiber silencers
Keihin pwk 28mm carburetors
Modified airbox
Lightened flywheel
Zeeltronic ignition
Ported engine block
TSS ypvs valves
Wossner 65mm pistons
Welded crank
Badass
Re: RD350Lc2 YPVS
#2 Post by Badass » Sat Oct 19, 2013 5:15 pm
Love it man, thanks for the revving it up and all, sounds good with those stock pipes. Also love the stock bars, Yamaha really got those right.
Locked power valves? what would you do that for?
Two strokes keep the mosquito's in check!!
1984RZ350 Bought with 2,600 mi. in 1998
SpecII Pipes, Complete engine rebuild, 30's, S. 1 Porting, Clutch, Self ported reed cages, T.D.R. reeds, Fork brace, Steering damper.
Jimmye
Re: RD350Lc2 YPVS
#3 Post by Jimmye » Sat Oct 19, 2013 9:02 pm
Badass wrote:Love it man, thanks for the revving it up and all, sounds good with those stock pipes. Also love the stock bars, Yamaha really got those right.
Thanks man!
My Power valves are broken...
Does not have the money to replace them now.
Then i got some problem with the generator.
The low speed winding generates just 18 ac volts.
The high speed winding generates just 2 ac volts.
Thats why i'ts not revving properly.
Sorry if the grammar is poor. :smt018
I'am from Sweden by the way. :smt001
Modified airbox
Lightened flywheel
Zeeltronic ignition
Ported engine block
TSS ypvs valves
Welded crank
